RCA HTS-3000 difficult to load movies now...any HAAALP? - AVS Forum | Home Theater Discussions And Reviews
Old 10-15-2008, 04:21 PM - Thread Starter
gruuvmunky's Avatar
It's a 3 disc player. used to not have issues loading movies but now it says 'Loading' for a bit then spits out the movie and reads 'Disc error'.
If you send the movie back IN ENOUGH Times, it may load and start playing.
After ANY movie starts playing there are no issues at all during the movie.
I don't know how to clean a 3 disc changer laser lense manually, so i used a cd cleaner CD with little brush thing on it..That didn't help at all.
Any thoughts on if its dirty lense or something else?
the player is 3 years old about.
THANKS
gruuvmunky is offline
