Oppo 980H vs. Pioneer DV-410V-k vs. Harman DVD-48 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-23-2008, 10:10 AM - Thread Starter
rispoli's Avatar
I am mostly interested in sound quality.
I have read everywhere owners raving about the sound quality of the Harman Kardon DVD-48 and of the Oppo 980H. What abou the Pioneer DV-410 which is by far cheaper than those and easier to buy?
Thanks for reporting your experience.
rispoli is offline
post #2 of 7 Old 10-23-2008, 10:53 AM
Blacklac's Avatar
Blacklac is offline
post #3 of 7 Old 10-23-2008, 11:01 AM - Thread Starter
rispoli's Avatar
Analog connection no but analog material yes, I do listen it often. I still listen CD although more and more often I am going towards mp3 eoncoded at 256kbps (cannot tell much difference from original analog).
All but the HK have a USB port, which I plan to use often.
I have a HK receiver, if that matters.
rispoli is offline
post #4 of 7 Old 10-26-2008, 12:09 AM
Pi-nk_Floyd's Avatar
I love my OPPO
Pi-nk_Floyd is offline
post #5 of 7 Old 10-30-2008, 10:10 PM
Doogsy's Avatar
I recently got the 410 and although there was an improvement over the picture there was a more noticable improvement over sound to my Marantz SR5300 via coax.
Doogsy is offline
post #6 of 7 Old 10-31-2008, 09:49 AM
Blacklac's Avatar
If your using digital connections, there won't be any difference. All the player is doing is passing the raw mix on to the receiver. It isn't doing any decoding.
Blacklac is offline
post #7 of 7 Old 11-02-2008, 03:51 PM
Doogsy's Avatar
Blacklac. are you saying thet every player will sound the same when using digital connections??? Glad i didnt spen anymore money !!!
Doogsy is offline
Reply DVD Players (Standard Def)
