Digital Coax Vs TOSLINK - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-01-2009, 04:31 PM - Thread Starter
Raymond Leggs's Avatar
TOSLINK SPDIF Vs COAX which is better?
A lot of DVDP's don't have the optical SPDIF, but have the coax. My sony DVDP only has coax.
My receiver has a COAX in and a COAX out what would the coax out plug into? I mean you already have better than TV sound, then hy would you want TV sound, or worse sound from the projector if that's what is for?
Raymond Leggs is offline
post #2 of 9 Old 01-02-2009, 09:48 AM
Mr. Audio's Avatar
Why don't you read your manual?
Your system can shine no matter what it's made of.......except if it's Bose.
Mr. Audio is offline
post #3 of 9 Old 01-02-2009, 03:50 PM - Thread Starter
I was jut wantering what other devices would have a COAX in besides a projector or TV.
post #4 of 9 Old 01-02-2009, 04:28 PM
Mr. Audio's Avatar
CD recorders. It is for recording purposes.
post #5 of 9 Old 01-02-2009, 06:13 PM - Thread Starter
cool.
post #6 of 9 Old 01-02-2009, 06:23 PM
AndyVincent's Avatar
Coax definately - anything else is just overated and over priced
AndyVincent is offline
post #7 of 9 Old 01-03-2009, 04:37 AM
kucharsk's Avatar
Quoted: 1265 Post(s)
Liked: 689
You may also want to use coax out to an outboard D/A converter better than the one in your receiver.
That way you can continue to use the receiver as a switcher but still improve your sound.
In general coax digital sounds better than Toslink, or rather timing errors are more easily injected into the data stream when using a Toslink interconnect.
However Toslink is completely immune from RF interference where coax is an electrical signal like analog audio signals are.
For most, however, there's no audible difference.
kucharsk is offline
post #8 of 9 Old 01-03-2009, 05:23 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
To me they sound the same but I prefer coax because it's not as fragile. I use so many inputs that I'm forced to use both.
joed32 is offline
post #9 of 9 Old 01-03-2009, 03:10 PM - Thread Starter
Agreed most TOSLINK cables are vulnarable to breaking and the glass lense can get scratched. Not to mention hoew much $$$ a good one which is not fragile costs.
Reply DVD Players (Standard Def)
