S-Video Vs. Composite Video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-20-2009, 08:57 AM - Thread Starter
ValjeanPhantom's Avatar
I have a Pioneer Elite DV-58AV connected via Composite video to an RF modulator connected to a CRT TV. I find myself constantly adjusting picture settings on my TV and DVD player every time I switch between viewing TV channels and DVDs. For TV channel viewing, I keep all my picture settings in the nutral position. For viewing DVDs, I turn the contrast on my TV and DVD player to the maximum position which helps with darker scenes, but then my TV color becomes funky. If I upgrade to S-Video, will the level on my DVD player match that of TV broadcasts so I can keep my settings in their nutral positions?
ValjeanPhantom is offline
post #2 of 8 Old 01-20-2009, 09:42 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 327 Post(s)
Liked: 6712
It's hard to say. S-video should give you somewhat better PQ. You need to use a calibration disc to see how things should look, at least according to the standards to which DVDs are mastered.
larry
Ich bin hier und du bist mein Sofa
PooperScooper is offline
post #3 of 8 Old 01-20-2009, 10:16 AM
QuiGonJosh's Avatar
Quoted: 246 Post(s)
Liked: 101
S-Video will provide a better picture with better sharpness and color saturation. I did a little comparison awhile back on a CRT and was really surprised how much better S-Video looked compared to composite.
QuiGonJosh is offline
post #4 of 8 Old 01-20-2009, 10:30 AM
tvtommy's Avatar
What kind of connections does your TV have? If you are using the RF modulator you are most likely getting losses in the video signal, which is not at it's best with composite to begin with. If your TV has separate inputs, use the RF for the the antenna or cable box, then use the composite video (yellow RCA jack) for the DVD. If the TV has a seperate S-video then use that for the DVD instead of the composite. If you have to use the modulator you might want to try a different one, perhaps the one you are using is funky.
"What is truth?" - Pontius Pilate
"I am the way and the truth and the light" - Jesus Christ
tvtommy is offline
post #5 of 8 Old 01-20-2009, 12:14 PM - Thread Starter
If my TV had any A/V inputs, I would have no reason to use an RF modulator. My TV only has a cable TV/antenna input. However, my RF modulator has Composite and S-Video connections.
post #6 of 8 Old 01-20-2009, 12:39 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
The RF modulator needs to convert S-Video signal format into composite format any way before modulate the signal. The problem you have might be related to the black level mismatch. See if your player can configure a different black level for analog out.
Foxbat121 is offline
post #7 of 8 Old 01-20-2009, 02:57 PM
Huey's Avatar
Sounds like you need a new TV. It's moot to use Svideo when you use RF modulator which is the worst connection possible between video devices. There should be a fire sale on may CRT type TV's (especially non-hi-def with some may have component, Svideo, composite, and RF connections) as most people are switching to HDTV due to 2/09 DTV deadline.
Huey ;-]
Huey is offline
post #8 of 8 Old 01-20-2009, 04:18 PM
QuiGonJosh's Avatar
Quoted: 246 Post(s)
Liked: 101
I've seen a couple of 27 inch CRT's at places like Wal-Mart for $200 or under. Both at Wal-Mart (RCA and Sansui I believe) had component inputs as well as S-Video and composite.
Reply DVD Players (Standard Def)
