Multi Region NTSC/PAL Player Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-05-2009, 06:14 PM - Thread Starter
Skakruk's Avatar
If I have a multi region NTSC/PAL DVD player, will there be any difference between the picture quality of NTSC and PAL disks?
Does the actual video information on a PAL DVD differ in any way to that of a NTSC DVD? (eg. resolution of frames, number of frames etc.)
Skakruk is offline
post #2 of 3 Old 02-06-2009, 03:49 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 336 Post(s)
Liked: 6994
NTSC is 720x480 and 24fps at 60hz for movies. PAL is 720x576 and 25fps at 50hz.
larry
Ich bin hier und du bist mein Sofa
PooperScooper is offline
post #3 of 3 Old 02-06-2009, 01:34 PM - Thread Starter
Skakruk's Avatar
larry
Thanks Larry.
Is it better to use the Progressive or Interlace setting on my DVD player when playig PAL DVD's? Does the same apply to NTSC DVD's?
Skakruk is offline
Reply DVD Players (Standard Def)
