Denon 758/1940 vs. Oppo 980 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-19-2009, 02:45 PM - Thread Starter
criagD's Avatar
Is there a $100 difference between the two? I think both use Faroudja processing, so will the upconversion be about the same? I think the Oppo can send SACD/DVD-A out the HDMI and the Denon can not. Is that about the only difference?
criagD is offline
post #2 of 4 Old 08-19-2009, 04:37 PM
moxie1617's Avatar
Oppo uses mediatek in the 980 not faroudja.
moxie1617 is offline
post #3 of 4 Old 08-19-2009, 08:36 PM
OtherSongs's Avatar
"Denon 758/1940 vs. Oppo 980"
I have an OPPO 981 (used extensively), and have given away a 980 unit as a gift, so I have some limited experience with that too.
The better deal is a roughly 80% off closeout DVD Denon unit; either a Denon 1940ci (which I own) $80.53 closeout + Free Shipping thru amazon
Or a closeout Denon 2930ci (which I also own) $199.88 + Free Shipping
I suggest you buy one or the other through www.amazon.com. Go there and search on: denon sacd player
FWIW I have nothing to do with amazon, but think that if there is any issue with a unit that you get using them (as primary with a secondary company) it is very very easy to deal with, whereas I don't have much trust in dealing directly with these secondary companies.
Cheers
The best is the enemy of the good. Voltaire (1694-1778)
OtherSongs is offline
post #4 of 4 Old 08-20-2009, 05:54 AM
jcalabria's Avatar
Quoted: 136 Post(s)
Liked: 105
Just picked up a Denon-refurbed 758 at uBid.com for less than $45 shipped. They are unloading lots of 50 daily. I didn't really need it as I already have a 980, but it was a good deal at that price. If it did SACD over HDMI I would probably replace the 980 with it (don't want to lose Audyssey because of using analog inputs). I will probably just replace an older non-HDMI player in one of my secondary systems with it.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
Reply DVD Players (Standard Def)
