standard vhs/dvd combo player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-05-2010, 06:12 PM - Thread Starter
Luisfc1972's Avatar
Quoted: 165 Post(s)
i need a recommendation for a vhs/dvd combo player only. i dont intend to record my vhs tapes, i just want something that will play them and dvds.
i am using a very old projection tv for this and it has no hdmi, just s video and the red white yellow analog.
i would like one with s video connection on it but would settle for analog. i want to use the tv speakers, no surround sound.
i cant seem to find anything out there except vhs to dvd recorders and they are more than i want to spend.
i tried a vhs to dvd recorder from costco and the recorded vhs to dvd movies did not work on other players even though the player manual said it could with copywrited documentaries/movies.
anything basic and cheap out there? id even settle for something with no remote.
Luisfc1972 is offline
post #2 of 4 Old 03-05-2010, 07:31 PM
jjeff's Avatar
Quoted: 706 Post(s)
Liked: 248
http://www.amazon.com/Panasonic-DMP-...3947137&sr=1-2
Maybe more than you want to spend, and doesn't have S-video output but at $149 and ability to play BR discs, it might fit your bill?
The Panasonic EZ-48v recorder(which you probably tried at Costco) is VERY buggy and I wouldn't suggest it. I really haven't heard anything bad about this player.
jjeff is online now
post #3 of 4 Old 03-10-2010, 05:54 AM
gar3's Avatar
I came here specifically to mention the Panasonic DMP-BD70v. In my opinion you'd be nuts to pass up a hi-def combo unit at the $150 price point. I realize you may not be able to utilize the Blu-ray portion at the moment but future-proofing yourself for just a couple of bucks more isn't necessarily a crazy idea.
gar3 is offline
post #4 of 4 Old 03-24-2010, 03:45 PM
jjeff's Avatar
Quoted: 706 Post(s)
Liked: 248
It's dropping, now $139 at Amazon.
http://www.amazon.com/dp/B001VZ1W5U/...2400_pe_vfe_d1
$259 off list
jjeff is online now
Reply DVD Players (Standard Def)
