Pioneer Laserdisc fix help - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #151 of 159 Old 04-19-2015, 07:11 PM
AVS Club Gold
Kurtis Bahr's Avatar
Quoted: 21 Post(s)
Wish I could find a SCQ3.8 but it doesn't exist. Don't go smaller than a SCQ3.6 as too much tension will wear out the bushings in the load motor.
Kurtis Bahr is offline
post #152 of 159 Old 04-19-2015, 07:58 PM
Dan Hitchman's Avatar
Quoted: 1936 Post(s)
Liked: 984
Originally Posted by Kurtis Bahr View Post
Here is the link to order from Pioneer, shipping/handling/tax will double the price or more. Part number VEB1184
http://parts.pioneerelectronics.com/...uctNum=VEB1184
Thank you!! Just ordered 2 as that seems to be a part that wears out quickly. Wish I could have canceled my Ebay order, but oh well.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #153 of 159 Old 04-26-2015, 02:28 PM
kenmoto's Avatar
Quoted: 30 Post(s)
Ok, I feel dumb. I am replacing the m-holder and got it out, but now not sure how these two attach to anything. Once I got the m-holder out, these just came loose.
kenmoto is offline
post #154 of 159 Old 04-26-2015, 02:53 PM
kenmoto's Avatar
Quoted: 30 Post(s)
Also, one of the shorter of the tiny screws that holds the holder to the motor fell into the abyss of the player. Turning the player around doesn't make the screw move, so it's being held down there somewhere. Anyone know the specs on those so I can get another?
Thanks again.
kenmoto is offline
post #155 of 159 Old 04-26-2015, 03:47 PM
kenmoto's Avatar
Quoted: 30 Post(s)
Ah, I guess this would explain why the m-holder stopped working. Once I realized those posts were broken off, I was able to figure out how to get it together. Just missing that screw now.
kenmoto is offline
post #156 of 159 Old 04-26-2015, 05:14 PM
Liked: 984
The Ebay SCQ4 band arrived sooner than the ones from Pioneer, so I tried it for ****s and giggles. It works perfectly. Now I'm out $24. Ah, se la vie!
post #157 of 159 Old 04-26-2015, 06:16 PM
kenmoto's Avatar
Quoted: 30 Post(s)
And I found the screw. Once I was able to secure the motor assembly in place, I could really tilt the player around until the screw slid out. All back together and working perfectly. Thanks especially to Kurtis. Now I can watch all my original Ultimate Collection Star Wars LDs in peace.
kenmoto is offline
post #158 of 159 Old 04-29-2015, 06:40 AM
Jpass992's Avatar
I'm having issues with both my CLD 79 and CLD 99. When I insert a disc the player groans then ejects the tray with a U1 error code. I bought replacement belts from the ebay seller but both players still have the loading issue.
Do I need the stock Pioneer belt or does the gear that raises the pickup need lubrication?
Jpass992 is offline
post #159 of 159 Old 06-21-2015, 01:21 PM
Liked: 0
Need help.
I have pioneer CLD- v850 ,the fuse blow up ,and i change 2 new fuse type 2A 250V but it keep blow up right a way after i plug in AC power,pleased help.
TQFL888 is offline
Reply DVD Players (Standard Def)
Pioneer , Pioneer Brand , Pioneer Electronics
