Pioneer LaserDisc / DVD thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
Old 12-27-2011, 12:39 PM
jantje112's Avatar
Well,
I have the dvl-919, not sure, but there was a player before that which took me into laserdisc. I believe it was a cld-1650 or something.
The 919 was my second unit, after heavy modding and adjustment it produced a very good picture (I put a lot of extra weight in the player so it's way more stable)
After some time I combined it with the vsx-918 with AC3RF input and the separate stereo amp (for the vsx-919)
Had a cld-515 for the bedroom and used a cld-925 for my HT.
Then I ended up with a CLD-R7G (great player!) and I have a HLD-X9 in the living, in my HT and one spare.. On the big screen a X9 is really great, combined with the Crystalio II or the VP50 (i have both) on the marquee 9500 it's really impressive. Not that much resolution, but an easy guarantee for a night of enjoyment..
Did I mention, the Muse, that's nice also. I have a few titles which are a very nice enjoyment, like dances with wolves and Universal soldier (I know )
I love the hobby which got me into LD, not sure if my 200 discs justify the collection of players.
jantje112 is offline
Old 12-28-2011, 09:21 AM
rencan's Avatar
Quoted: 13 Post(s)
Originally Posted by vcrpro3 View Post
Even though i have had the equipment for a while, a Lexicon LDD-1, Kenwood DEM-999 and a couple of CLD-D704's, i hooked them up and watched a AC-3 soundtrack of 'Die Hard With A Vengence' and it sounded great on my system...too bad that i'm soon getting out of LD and downsizing to blu ray....
I have an LDD-1 and a CLD-79 tied into my SC-27 but I can't get an AC-3 signal. The LDD-1 is supposed to lock into the the signal but can't get it to work for some reason. I have the owners manual for the LDD-1 and installed per instructions.
Any ideas on why i can't get the AC-3 signal?
Thanks in advance.
rencan is offline
Old 12-28-2011, 10:32 AM
The Lizard King's Avatar
Thanks in advance.
Do you have your CLD-79 and LDD-1 set up like this?
TLK
The Lizard King is offline
Old 12-28-2011, 02:25 PM
Zenyatto's Avatar
Quoted: 27 Post(s)
L Z:
WHY so many connections? I don't understand this Lexicon. I connected the LD player AC-3 out to the Yamaha OB DEM AC-3 coax IN. Then either the Yamaha optical or coax(my preference) OUT to the AVR DIG Coax Audio IN(properly assigned)>VOILA AC-3 signal in business!
Two connections/two cables:
OUT to IN>IT>Simple
Zenyatto is offline
Old 12-28-2011, 02:58 PM
rencan's Avatar
Quoted: 13 Post(s)
I'll give that a try when i get home this evening.
rencan is offline
Old 12-28-2011, 03:10 PM
Originally Posted by Zenyatto View Post
L Z:
WHY so many connections? I don't understand this Lexicon. I connected the LD player AC-3 out to the Yamaha OB DEM coax IN. Then either the Yamaha optical or coax(my preference) OUT to the AVR DIG Coax Audio IN(properly assigned)>VOILA AC-3 signal in business!
OUT to IN>IT>Simple
If his receiver only has one digital audio input, the LDD-1 acts as a switcher between AC-3 and digital audio as a pass-through. This allows him to have more than one device hooked up to the digital audio inputs of his receiver.
Actually, disregard the light blue connection. Use that digital coaxial input from a DVD/BD player, instead, or nothing at all.
TLK
Old 12-28-2011, 03:17 PM
rencan's Avatar
Quoted: 13 Post(s)
TLK
if it doesn't work then it would seem that my LDD-1 is defectiver right?
rencan is offline
Old 12-28-2011, 03:19 PM
Either that or your AC-3 RF output on your CLD-79 is defective.
TLK
Old 12-28-2011, 08:15 PM
Kurtis Bahr's Avatar
Quoted: 48 Post(s)
Liked: 25
TLK
Take an ohm meter and measure the CLD-79 output. you need to measure the center pin to the ground. It should read around 4.0VDC when a LD is playing and near 0.2VDC when paused or not playing. Also the Lexicon has some selections on the front. One of them is a bias to match the LD player differences. I found it didn't make a difference with my AC-3 addition to my CLD-97 but you never know.
Kurtis Bahr is offline
Old 12-28-2011, 08:16 PM
Quoted: 48 Post(s)
Liked: 25
If you have an oscilloscope you will be able to see a 300 to 500mV RF signal that rides on the 79 output DC level.
Old 12-28-2011, 10:10 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
My question about the designation of the surround format called 'Dolby Surround' on the disc sleeve was prompted also by my inability to get my Lexicon to pick up the RF signal...Solution?....double check the title i was playing to make sure it says on the disc 'Dolby Surround AC3'.
Thanks in advance.
vcrpro3 is offline
Old 12-28-2011, 10:12 PM
Most AC-3 titles that I own state that the audio is encoded as "Dolby Digital."
TLK
Old 12-28-2011, 10:30 PM
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Yep, That too!!!
TLK
vcrpro3 is offline
Old 12-29-2011, 01:18 AM
Zenyatto's Avatar
Quoted: 27 Post(s)
TLK
The AC-3 LD's were manufactured between 1995-1997(early). Dolby Laboratories then decided to label the AC-3 titles DD to avoid confusion which coincided with the DVD introduction.
Zenyatto is offline
Old 12-29-2011, 08:55 AM
rencan's Avatar
Quoted: 13 Post(s)
I wired it in last night and it did not work. I followed TLK's diagram and the LDD-1 did not lock on to the AC-3 signal. I only have one AC-3 disk (Top Gun) but do plan on purchasing more in the future along with DTS encoded disk.
I'll check ohms tonight.
I realize it's obsolete technology and my wife thinks I'm nuts but "oh well"!
Thanks again everyone.
rencan is offline
Old 12-29-2011, 09:28 AM
I assume that your Top Gun LD is this one?:
http://www.lddb.com/laserdisc/21964/...Top-Gun-(1986)
If so, then it's either a problem with your player or demodulator, more than likely.
TLK
Old 01-03-2012, 02:58 AM
MV_Cinema's Avatar
Finally Aliens Box Set is becoming more valuable...
http://www.ebay.com/itm/ALIENS-Laser...item2567b3bff4
It's an awsome box set, and i was always wondering how value it would become.
I am glad a have a Sealed, Mint copy.
MV_Cinema is offline
Old 01-03-2012, 03:14 AM
EJ
EJ's Avatar
You have to be careful with this title, as it has a high risk for laser rot. I've owned it since it's release, and mine has rotted.
Laserdisc Database has multiple copies for sale ranging from $3 to $98. I don't mean to burst any bubbles, and I'll gladly eat those words if he gets anything close to asking price.
http://www.lddb.com/laserdisc/00876/...-Edition-(1986)
Former USSB uplink operator.
EJ is offline
Old 01-03-2012, 08:03 AM
denvertrakker's Avatar
Just because somebody throws something up with an outlandish BIN, doesn't mean it will sell at that price. Someone keeps putting up a CLD-D704 that doesn't work asking $130 or so for it, with no takers for about the fifth time. No surprise there.
As the previous post says, I'll eat my words too if it sells...
denvertrakker is offline
Old 01-03-2012, 08:19 AM
MV_Cinema's Avatar
You got your point.
I was only glad, because i always looked at it as a great title.
I've never seen mine actaully. I've opened Alien (same Edition) and doesn't has any rot (saw it twice), but Aliens i don't know...
I will check one of these days..
Old 01-03-2012, 10:42 AM
Josh Z's Avatar
Quoted: 2137 Post(s)
Liked: 1434
You got your point.
As mentioned, Aliens is a notorious rotter. Back in the day, I had to swap out discs from multiple copies until I could compile one complete working set. Fortunately, there was a local LD store at the time with a good return policy that let me do this.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
Old 01-04-2012, 12:00 PM - Thread Starter
toyfreaks's Avatar
Has anyone collected data about conditions that foster laser rot or tried reversing or preventing it through any particular means? I am guessing the rot comes from actual oxidation on the aluminum, versus air pockets between the disc layers.
Has anyone ever tried heating and repressing a disc? or storing them in a low-oxygen environment?
I bought a collection of discs a couple years back that included several severely rotted titles that were so bad they had gold sparkles in the substrate. Looked like they should have glowed in the dark. Julien Wilk of the LDDB said they were the worst he had ever seen.
In each case, the rice paper sleeve was ether stuck to the disc or so dessicated that it crumbled like Egyptian mummy bandages on contact... but only on the side that was rotten! Strangely, in almost every case, there was no sign of rot on the flip side of those crazy disks!
toyfreaks is offline
Old 01-04-2012, 12:03 PM - Thread Starter
toyfreaks's Avatar
...and it was mostly on blank side 4! Has anybody else come across these... ahem... super collectible rare "sparkletone" discs??
Old 01-04-2012, 04:16 PM
EJ
EJ's Avatar
Laserdisc rot occurs when the glue holding the 2 sides together breaks down allowing air to oxidize the material between the 2 pieces of plastic.
EJ is offline
Old 01-06-2012, 02:34 AM
EJ
EJ's Avatar
Well, I think I'm about to call my laserdisc collection complete. I've got many films to watch and demonstrate, and it's too the point where they're getting too pricey. I was looking at an ebay copy of Crimson Tide that seemed like a good deal, but I found a blu ray on Amazon for about $5 less.
I know it's apples and oranges, but laserdisc just can't be expected to compete with a 1080p apple!
EJ is offline
Old 01-06-2012, 01:27 PM
Glimmie's Avatar
Quoted: 729 Post(s)
Liked: 592
Even standard DVD! If the movie was re-transferred in component video to DVD, it will surpass any Laserdisk. Now some don't like the particular edited version released on DVD versus LD, but that's another story. However some low market films may just be encoded to DVD using the old 1inch NTSC master rather the go through an expensive film re-transfer. In this case the LD is most likely better.
The only thing really valuable on LD, IMO, is live events like concerts from the 1980s and early 90s. These are forever locked into NTSC video and an LD is about the best you can get. Most DVD transfers of these are not very good.
Glimmie is offline
Old 01-06-2012, 01:28 PM
If everything is the same, I'll always opt for Blu-ray over LD or DVD. I only buy LDs that have features/content that doesn't exist on either of the two newer formats.
TLK
Old 01-06-2012, 02:05 PM
Zenyatto's Avatar
Quoted: 27 Post(s)
Crimson Tide DTS LD anyone?
Zenyatto is offline
Old 01-06-2012, 02:08 PM
kemiza's Avatar
Liked: 92
I got it!
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
Old 01-12-2012, 08:44 PM
EJ
EJ's Avatar
I have "squeeze laserdisc" as a search string on ebay, hoping to catch any anamorphic discs that might pop up. This was today's listening.
http://www.ebay.com/itm/City-Squeeze...item35b8960fb2
EJ is offline
Pioneer , Pioneer Brand , Pioneer Electronics
