Pioneer LaserDisc / DVD thread - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #601 of 1015 Old 04-09-2012, 03:50 PM
Kurtis Bahr's Avatar
Quoted: 56 Post(s)
Liked: 27
Originally Posted by toyfreaks View Post
The rails were down and the pickup was up toward the front. I was able to easily push it all the way back, but still nothing at all on powering up or pressing buttons. No motor, no servos, not even the pickup test for disc.
:P
As soon as the unit powered on the pickup should have moved forward to the correct rest position even without a disc installed. This is acting so much like the turn mechanism in the back is not properly in the A side position.
Kurtis Bahr is offline
post #602 of 1015 Old 04-09-2012, 09:45 PM
EJ
EJ's Avatar
Well, I received the Star Wars trilogy CEDs. It did include both Jedi discs, and they look like I'd just opened them. No scuffs or scratches. If I were to sell them, I would have no problem listing them as mint.
Former USSB uplink operator.
EJ is offline
post #603 of 1015 Old 04-10-2012, 08:59 AM - Thread Starter
toyfreaks's Avatar
@EJ: Those are really nice. If you are looking for any other titles, let me know
toyfreaks is offline
post #604 of 1015 Old 04-10-2012, 09:01 AM - Thread Starter
toyfreaks's Avatar
Originally Posted by Kurtis Bahr View Post
As soon as the unit powered on the pickup should have moved forward to the correct rest position.
I will take another look. The pickup slid all the way back into the turn mechanism, so it seemed to be in the correct position.
post #605 of 1015 Old 04-11-2012, 01:08 PM
MV_Cinema's Avatar
Now my Sony MDP-740 besides not reading the disc (the disc wants to start spinning, and makes 2 attempts, the first one slower and the second one faster, but then stops, doesn't rcognizes the disc) is also making a strange thing.
When i open the drawer the aluminium door tries to open but stays in the middle of the process, i must help with my finger.
Any ideas for these 2 problems?
MV_Cinema is offline
post #606 of 1015 Old 04-13-2012, 11:42 AM
tinpanalley's Avatar
Quoted: 84 Post(s)
Back on the power supply where the AC line goes into it there is a fuse, you to check and see if it is blown, if it is, cut out the suppressor diode and buy the same exact fuse that is in your player. The power supply board should also be marked with the volts and amps needed for the replacement fuse.
Is there any chance someone has a manual for disassembling my CLD-D504? Or is it pretty straight forward unscrewing and carefully remembering where things go?
tinpanalley is offline
post #607 of 1015 Old 04-13-2012, 01:42 PM
Quoted: 56 Post(s)
Liked: 27
Under the tray on the left front you will find the pully to open the tray, turning it one way ejects the tray, turning it the other lifts the mechanical assembly. Once the tray is out the power supply is righ tthere on the bottom left.
post #608 of 1015 Old 04-13-2012, 02:03 PM
Quoted: 56 Post(s)
Liked: 27
One other thought, if the tray is not fully pulled into the player it will also act like this. There is a micro switch that signals the processor that the tray is in play position and that signal is necessary for it to try to play but with this failure the tray should open/close. Could also be the ribbon cable going from the turn mechanism to the electronics board.
post #609 of 1015 Old 04-14-2012, 01:50 AM
Reinbo's Avatar
Jason & Snake taking Manhatten
Reinbo is offline
post #610 of 1015 Old 04-14-2012, 02:15 AM
Jason One's Avatar
The rubber clamp surface on the top of the spindle motor needs a through cleaning or replacement.
Thanks, Kurtis. I opened it up and did a quick cleaning. After a brief test, it seems to be working better.
I should mention that I actually bought this player from you a while back. I've been very happy with it!
Jason One is online now
post #611 of 1015 Old 04-14-2012, 09:46 AM
WhiteWhiskers's Avatar
I was curious to see if my CLD-D703 still worked. The last time I used it two years ago it had serious tracking problems. It would play discs fine in the beginning but would lose tracking towards the end of the disc.
To my surprise it played two Pioneer USA discs perfectly. But a disc made at DADC/Sony is completely unplayable now. I put in the disc, the disc spins up faster and faster and faster. And then the player gives up and drops out of play made. I can't even eject the disc as the brake never engages. I have to wait until the disc spins down to a stop on its own and then the eject button works.
WhiteWhiskers is offline
post #612 of 1015 Old 04-14-2012, 03:01 PM
MV_Cinema's Avatar
Just send it to Sony to replace the parts. It's a very complex and beautiful machine , it deserves to be renewed.
post #613 of 1015 Old 04-15-2012, 11:59 AM
Quoted: 84 Post(s)
Ok, thanks. But I assume I take screws out of the bottom first?
post #614 of 1015 Old 04-16-2012, 01:16 PM
Reinbo's Avatar
Cool psychedelic stuff in 3D
Reinbo is offline
post #615 of 1015 Old 04-21-2012, 02:57 AM
Reinbo's Avatar
My Criterion Collection on laserdisc
Reinbo is offline
post #616 of 1015 Old 04-21-2012, 01:32 PM
Tom Monahan's Avatar
Location: Butte, Montana Hometown of the late Evel Knievel
Quoted: 60 Post(s)
Liked: 43
Is the composite out on the CLD-95/97 much better than the CLD-79?
Tom
My equipment: JVC RS55 for 2D, BenQ W7000 for 3D, Carada 40x117 2.925:1 AR BW Criterion screen, Navatar .8 HD conversion lens, Darbee Darblet, region free Oppo BP93, Toshiba HD-A35 HD-DVD, JVC HD-DH5U D-Theater, Mitsubishi HS-HD 20000 DVHS, Pioneer CLD-97 LD player/AC-3 mod, B&K AC3 Demodulator
Tom Monahan is offline
post #617 of 1015 Old 04-22-2012, 01:51 PM
The Lizard King's Avatar
IMO, yes.
TLK
The Lizard King is offline
post #618 of 1015 Old 04-22-2012, 08:07 PM
Quoted: 56 Post(s)
Liked: 27
Tom
In my opinion yes the 95/97 are better, but it depends on what you like. The 79 will have more background noise but be a little sharper. The 95/97 will be more film-like with a smoother background but not quite as sharp.
post #619 of 1015 Old 04-24-2012, 11:21 AM
Quoted: 60 Post(s)
Liked: 43
Thanks Kurtis
A CLD-79 sold on Ebay today for almost $400 while a CLD-95 sold for $205 and a CLD-97 for $400 days ago. I kick myself for not bidding on the 95/97and selling that mint 97 last year that you worked on.
Stupid is as stupid does I guess.
Tom
post #620 of 1015 Old 04-24-2012, 02:06 PM
Quoted: 56 Post(s)
Liked: 27
Thanks Kurtis
Tom
If you ever want another 97 let me know
post #621 of 1015 Old 04-24-2012, 08:16 PM
What extras are on the CAV Akira LD that are not on the Blu-ray or the DVD?
TLK
post #622 of 1015 Old 04-27-2012, 06:55 AM
MV_Cinema's Avatar
I don't mean to harm anybodys feelings here, but this Forum is DEAD, in what concerns to Laserdisc.
post #623 of 1015 Old 04-27-2012, 10:47 AM - Thread Starter
toyfreaks's Avatar
note to self: feelings hurt... forum dead... ok thanks!
post #624 of 1015 Old 04-27-2012, 10:50 AM - Thread Starter
toyfreaks's Avatar
Anybody know anything about the Sony LVR-3000N laser disc recorder? There is one for sale with a single unused LVM-3AA0 Blank CRV Laser Videodisc.
Can CRV discs be played on a standard LD player? From what the seller knows, they were made only to play in CRVdisc players or recorders.
post #625 of 1015 Old 04-27-2012, 11:04 AM
TheGiver's Avatar
The seller would be correct. I remember reading that those are locked away in a caddy. I don't think CRV was even interchangeable between other CRV devices, the Sonys only played in Sonys, the Panasonics only played in Panasonics. A nice piece of history in the LaserDisc subculture, though
TheGiver is offline
post #626 of 1015 Old 04-27-2012, 01:43 PM
Quoted: 56 Post(s)
Liked: 27
There were two type of recorders made. The one with the caddy so you could only play them in units made for them and another that did not have a caddy but the player had to be designed to play the disc. The LD-V4400 industrial was made to read those. I do not know of any LD recorder that used a disc you could put into any LD player.
post #627 of 1015 Old 04-28-2012, 10:05 AM
Ha ha ha ha ha!
TLK
post #628 of 1015 Old 04-28-2012, 11:59 AM - Thread Starter
toyfreaks's Avatar
The one with the caddy so you could only play them in units made for them...
Crap. I really wanted to put Penelope Spherris' film Suburbia on LaserDisc. Surprised it never made it, considering at came out at just the right time (1983)
post #629 of 1015 Old 04-28-2012, 01:14 PM
What's your source medium for the film?
TLK
post #630 of 1015 Old 04-28-2012, 05:23 PM - Thread Starter
toyfreaks's Avatar
TLK
It was released on VHS and DVD as far as I know, but then what's the point? I also thought it would be cool to make my own movie and put it on LaserDisc, but not if I am the only one who can play it.
Reply DVD Players (Standard Def)
Pioneer , Pioneer Brand , Pioneer Electronics
