Pioneer LaserDisc / DVD thread - Page 32 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #931 of 1015 Old 06-04-2014, 02:39 PM
Kurtis Bahr's Avatar
Quoted: 56 Post(s)
Liked: 27
One possibility would be if the laser cannot move to the rest position or the turn mechanism in the back is not locked in side a or b position the unit will not respond
Apostate likes this.
Kurtis Bahr is offline
post #932 of 1015 Old 06-04-2014, 06:54 PM
Apostate's Avatar
Quoted: 100 Post(s)
Liked: 134
Why does Kurtis Bahr have only 12 thumbs up??? eek.gif He's a godsend to this forum. I need to give him some thumbs up.
www.laserdisc.ws likes this.
Apostate is offline
post #933 of 1015 Old 06-30-2014, 11:15 AM
tylerernie's Avatar
It is locked in side a but I still get no response
tylerernie is offline
post #934 of 1015 Old 06-30-2014, 06:11 PM
Quoted: 56 Post(s)
Liked: 27
You may need to try to physically move the pickup either forward or back a little and see what happens if it still does not help then the next culprit could be the position switches.
post #935 of 1015 Old 07-01-2014, 07:18 PM
tylerernie's Avatar
Yea moving the pickup did not help
post #936 of 1015 Old 07-02-2014, 04:35 AM
Quoted: 56 Post(s)
Liked: 27
There are some switches on the bottom toward the spindle motor. Try depressing and releasing a couple times. Also try the one on top. If this doesn't work you should think about a new player. I do have one I could sell you.
post #937 of 1015 Old 08-09-2014, 05:39 PM
Liked: 0
Novice question
Hi, I'm not really much familiar with setting up AV outside of simple connectivity and need some advice with regard to setting up some older equipment. I have a Pioneer VSX-29TX receiver and a Pioneer DVL-91 laser disc player that would like to connect to a Sony Bravia HDTV. I have the manual for the receiver but not for the LD player. Both components have a lot of inputs/outpuits and I'm not really sure what the optimal setup would be. What I'd like to accomplish is to connect the LD player to the receiver and the receiver to the TV if that's the best option. Outside of HDMI, the TV is limited to just a couple of component inputs and no S-Video. It doesn't appear that the receiver has any component video output but the LD player does. They both have optical connectors so that might be an option. Any advice would be greatly appreciated. Thanks.
William Fleitz is offline
post #938 of 1015 Old 08-09-2014, 07:37 PM
tylerernie's Avatar
That didn't help. If you still have the player and would still like to sell it I might be able to buy it from you
post #939 of 1015 Old 08-09-2014, 07:51 PM
TheGiver's Avatar
Component on the later LD/DVD combo players will only output DVD. LD is recorded in composite space, so you'll get the best LD quality using the composite output, which can be made better through a VP with a good comb filter. The S-Video output will likely output a picture that goes through the LD player's internal comb filter. Your best bet is to try each and pick the one that looks best to you.
As for component video out on the DVD side, it will likely be an interlaced image, so while colors will be better and the image slightly sharper, if you don't put it through a good deinterlacer, you'll notice some extra artifacts.
(This post may need to be corrected, as my memory may be a bit rusty)
TheGiver is offline
post #940 of 1015 Old 08-09-2014, 08:00 PM
Quoted: 56 Post(s)
Liked: 27
Cannot remember which player I have that I told you about. I have a CLD-99 on eBay, I have a CLD-53 with AC-3 RF added and an older CLD-3070. You can write me at kbahr@comcast.net if you want to discuss a purchase.
post #941 of 1015 Old 08-10-2014, 08:45 AM
Liked: 0
Thanks for your reply. I'm not quite sure what a VP or comb filter are but I can certainly try the standard video output on the LD and see how that looks. I guess I'm not really as much concerned about "high def" quality but I do have some older LDs which don't have DVD releases and some of the older Criterion LDs so it's more of a case of setting something up simply to watch those. I'll try the simplest setup first and see how that goes. Thanks.
post #942 of 1015 Old 08-21-2014, 04:46 PM
Liked: 0
I'm almost certain this has been answered before, but bear with my inability to search forums efficiently.
Now, My buddy picked up Cld-D604 laserdisc player at Pawn America. I personally never shop there due to bad customer service and defective products in the past, and this was no exception. The player he received was essentially dead.
I ordered a replacement spindle motor off of the Pioneer Website (it came all the way from Japan!) and replaced that. Now thing plays both CD's and Laserdiscs without much issue.
The problem I AM having though, is that when playing a laserdisc, the lift mech is..... fickle. It'll go halfway up, and then I have to nudge it upwards (have to have the top case off). I don't have this issue when playing CD's.
So, I've read that it's either a slipping belt or some binding in the metal track (???). Sooo, I can't really find the belt I'm supposed to be looking for. I think the pictures I saw must be for a different model. If the track needs re-allignment, I guess I need to know what that would entail.
We figured out the hard stuff, so if you can help me with this small issue, I'd be super grateful!
dhiz is offline
post #943 of 1015 Old 08-22-2014, 09:09 PM
Quoted: 56 Post(s)
Liked: 27
Open the tray all the way and you'll see it under the tray at the front left.
post #944 of 1015 Old 08-23-2014, 10:09 PM
Liked: 0
Aha! I figured that belt was only used for the tray-eject action, not both. I'll clean that bit up, and if that doesn't work, I'll try a new belt. I read somewhere it's belt no SCQ4.0. I'll let you know if things improve.
Edit: Well, it works better. I've tried it a handful of times now, and what will generally happen is it will try once, make the grinding not working noise, and spit it back out. Then, on an attempt immediately afterward, it will work and play. I'll order a new belt, see if we can increase this from a "works 75%" to "works 100%".
Last edited by dhiz; 08-23-2014 at 10:40 PM. Reason: Edited for avoiding a double post
dhiz is offline
post #945 of 1015 Old 08-31-2014, 07:32 PM
Liked: 0
Pioneer CLD-S104 belt
I just got my old LD player out of storage and it has a broken belt. Any idea where I can pick up a replacement? Thanks.
jdgoulden is offline
post #946 of 1015 Old 08-31-2014, 11:50 PM
Jim Parys's Avatar
Any ideas how to fit my HLD-X0 into my Midatlantic Slim5 rack. Its is about 1 inch wider than the face of the rack. Thinking of carefully tilting the player to its side to pass through the front of the rack then tilt back into position. Not sure it will work or not.
Jim Parys is Living the dream...
La Sirena III Theater
Jim Parys is online now
post #947 of 1015 Old 09-01-2014, 06:31 AM
ede
Liked: 0
New post here from a newbie. Hope I'm not violating any protocol but this seemed like an active and relevant thread. I have a Pioneer CLD 99 that the drawer won't open. The gear just spins on the rack and displays error code E3. The faceplate does not retract and I can't seem to "help" it manually either. Visually nothing appears broken. Any help or advice is appreciated. I'm in Phoenix AZ. Not sure of any trustworthy LD repair here......Thanks in advance, Ed
ede is offline
post #948 of 1015 Old 09-01-2014, 06:43 PM
Quoted: 56 Post(s)
Liked: 27
The CLD-99 does not have a retracting face plate, the face for the drawer is attached to the front of the drawer, This post is too confusing to me to be able to answer. Are you sure it is not a CLD-97?
post #949 of 1015 Old 09-03-2014, 09:58 AM
ede
Liked: 0
Sorry about any confusion Kurtis, it is definately a CLD 99. I apparently made an incorrect assumption the face plate retracted but not based on a visual observation. So the drawer moves "with" the face plate to the open position when operating properly?. (I couldn't remember) Right now when the drawer tries to open the motor spins the small nylon gear on the nylon rack but does not produce any movement. It grinds for about 10 seconds then stops and displays E3. I tried to help move the disc tray but it did not want to budge with minimal force. I can't see anything bound up or broken and I am reluctant to force anything. This unit has operated flawlessly for years and has not been moved or mishandled. Thanks.......Ed
ede is offline
post #950 of 1015 Old 09-03-2014, 02:12 PM
Quoted: 56 Post(s)
Liked: 27
I'd remove the top and verify the assembly is not trying to raise up before lowering and opening the tray. A video of this would be great to help. As if the drawer is closed you cannot see the gears unless you are looking under the tray. Also players have been know to get out of sync and you have to force them open and cycle open-close to get them going again.
post #951 of 1015 Old 09-03-2014, 07:37 PM
ede
Liked: 0
Thanks for the reply Kurtis! I'm trying to attach a couple pictures. The little white gear is spinning on the white rack but there is no movement. I misinterpreted what the grinding rack and gear function is. It appears to be trying to drive the optical pick up unit to the rear to a "safe" position prior to opening the tray? The tray never attempts to open and is very resistant to me trying to force it. I can try a video later if it will help. I did find the CLD 99 manual online and will print tomorrow so at least I can identify components correctly! Hope the pictures help, thanks a lot for your assistance....Ed
ID:	245041   Click image for larger version
ede is offline
post #952 of 1015 Old 09-04-2014, 02:09 PM
Quoted: 56 Post(s)
Liked: 27
You need to push the laser assembly backward with power off until it hits the stop. I have seen where the pickup moves forward when powered on before. Then power it on and see what happens. Email me at kbahr@comcast.net and let me know what happens.
post #953 of 1015 Old 10-25-2014, 07:24 AM
pkepneriv's Avatar
Originally Posted by toyfreaks View Post
A general thread for people to discuss general LaserDisc topics, especially maintenance and repair issues.
I shot this video yesterday and combined three of my favorite things, Video Equipment, Classic movies (StarWars), and Laserdiscs. I didn't take clips from the entire movie because I didn't want to get in any trouble for copyright or anything else. Anyway this video shows you what laserdisc are and how they work. Enjoy!
Equipment used:
Projector - BenQ MS513
Laserdisc player - Pioneer DVL-909
Laserdisc - Star Wars Trilogy Special Edition
Camera - Panasonic GH2
Lens - Canon FD 28mm f/2.8
Lens - Canon FD 50mm f/1.8
Lens - Canon FD 85mm f/1.8
Lens - Lumix 14-42mm
Slider - StudioFX 40"
Tripod - Fancier FT-717
http://youtu.be/X4Wq6fXuSn0?list=UUrVPGl112Z92rzrUs57dBiQ
pkepneriv is offline
post #954 of 1015 Old 11-03-2014, 10:10 PM
Quoted: 16 Post(s)
Liked: 6
LD enthusiast here, currently have a CLD-D704. I'm in the market for a new receiver that has a 1080p upscaler to feed either my 56" or 73" DLP. I also have a Sony Hi-Scan CRT which makes laserdiscs looks pretty good.
yuri53122 is offline
post #955 of 1015 Old 11-04-2014, 08:40 AM
CassidyEveyn's Avatar
I have only purchased laserdisc movies that were never released on DVD.
CassidyEveyn is offline
post #956 of 1015 Old 11-04-2014, 09:30 AM
calculon68's Avatar
Quoted: 116 Post(s)
Liked: 63
I picked up a fairly inexpensive Pioneer AVR two years ago that features composite video scaling by Anchor Bay. Controls are fairly rudimentary and your options are limited. I usually leave it at the "PURE" setting (no scaling) and let the TV scale it instead. Odds are your TV set will scale it better than the AVR. Not sure about projector's scaling abilities.
calculon68 is offline
post #957 of 1015 Old 11-19-2014, 03:39 PM
ELIE BARNES 3's Avatar
i also own a cld-704, a pioneer 59txi, a cheap $40 scaler and a 40" lcd tv.
looks really good.
ELIE BARNES 3 is offline
post #958 of 1015 Old 11-21-2014, 09:02 AM
Tasuke's Avatar
Liked: 8
1988 CLD-3030 LD player:
Tasuke is offline
post #959 of 1015 Old 01-14-2015, 09:03 AM
Liked: 0
I need to re-grease my LD-V4200, and was curious of a good brand of grease to use.
thanks
mike
bigmix007 is offline
post #960 of 1015 Old 01-20-2015, 04:03 PM
Liked: 0
bump
Reply DVD Players (Standard Def)
Pioneer , Pioneer Brand , Pioneer Electronics
