Pioneer LaserDisc / DVD thread - Page 33 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #961 of 1015 Old 01-20-2015, 06:31 PM
jd213's Avatar
You might want to try asking on the LDDB forums or directly contacting Kurtis Bahr, not sure if many people follow this thread anymore.
jd213 is offline
post #962 of 1015 Old 02-01-2015, 12:59 AM
67 - 427's Avatar
DOW CORNING MOLY KOTE EM-30L Full Synthetic Grease is what I used on mine, it claims it is safe for nylon, plastic and metal gears. 1 OZ container is about $9 shipped on ebay
67 - 427 is offline
post #963 of 1015 Old 02-22-2015, 05:47 PM
Liked: 0
CLD-V2600 Error Code E-02
Hello all,
Was referred here by some folks in hopes of repairing my LaserDisc player, a Pioneer CLD-V2600. It displays the error code E-02 - one that I cannot find a mention of in the manual or online. After I press the power button, it turns on and all the lights illuminate on the front display. Blinks the word "disc" for several seconds before giving the E-02 code. I can press the eject button and it acts like it wants to eject the tray, but it never does.
Then I tried tilting the player to where the front was facing the floor and tried ejecting the tray. It actually ejected and worked for a few times--the laser assembly moved up and down like it should without any issues. I loaded an audio CD and it recognized the CD, but never attempted to play it. After that, it ejected the tray but refused to pull it back in, and produced the E-02 error again. Then I could manually pull the tray out and push it back in. And now, it responds to me pushing a button, but nothing mechanically moves unless I move it manually.
In short, it thinks it is doing something when I press a button, but it does nothing. I have not forced anything to move if it isn't moving. All of the belts that I can see appear to be in good condition.
What could be causing this?
Dewster is offline
post #964 of 1015 Old 02-23-2015, 03:40 AM
tanwn1's Avatar
Quoted: 90 Post(s)
The belt may look good but may have lost its tension after all these years. Try to change the belt first.
tanwn1 is offline
post #965 of 1015 Old 02-23-2015, 08:55 AM
Liked: 0
When it does work, (at least as much as it has...) all of the belts and tray move as they should. The tray opens and closes normally, the laser slider piece moves up and down to accommodate the tray opening, and the laser piece itself moves horizontally as it should to read the disc. Then when it doesn't work, it is like it looses track of where it was; becomes disoriented. I can press buttons on the front and it acts like it is doing something (front panel displays "OPEN" when I press eject and displays "CLOSE" when I press eject again), but nothing moves. None of the motors attempt to move nor does the laser assembly move. Confirmed this by taking the belts off when it stopped working and the tray was open. Pressed the eject button and none of the motors made an attempt to move.
Dewster is offline
post #966 of 1015 Old 02-23-2015, 05:48 PM
Kurtis Bahr's Avatar
Quoted: 56 Post(s)
Liked: 27
If the laser has issues moving to the correct spot then this has the same m-holder as the CLD-D504/604 and other similar based players where the tabs that hold the two movement gears break loose and the gears float and sometimes work and sometimes don't.
Kurtis Bahr is offline
post #967 of 1015 Old 03-06-2015, 09:26 AM
Liked: 0
Yesterday, the player randomly started working without issues. I was able to play some LaserDiscs all the way through and also played some audio CDs. The tray and laser assembly moved without issue. I then unplugged it for the night. So I assumed that it would continue working again today. Wrong! Plugged it back in this morning, and it started to move the laser. The assembly moved into place and the laser lens moved up and down two times (IIRC, it moved up and down three times when it was working) and stopped; gave the E-02 error code after a few seconds. And now it is back to a completely non-functional state where absolutely nothing moves when buttons are pressed.
Would this still be indicative of a bad m-holder piece needing replacement?
Dewster is offline
post #968 of 1015 Old 03-06-2015, 02:05 PM
Quoted: 56 Post(s)
Liked: 27
The M-holder can cause movement issues so if still is a possibility. The part is cheap enough it is worth trying if you unit still has the gray colored holder
post #969 of 1015 Old 03-21-2015, 04:22 AM
leev's Avatar
Quoted: 14 Post(s)
Hi all I lave a Pioneer CLD 925 UK machine which has been playing fine until recently. I have had the same error with two UK laserdiscs from the early 80s. In both cases the machine will fail to play side b either by turning from side a or when side b is loaded face up. The machine attempts to load and then fails and displays the code P5. All the other discs in my collection play fine. Do you know what P5 means and is this a player or disc issue and can it be fixed? Thanks for any assistance you can offer. Lee :blush:
leev is offline
post #970 of 1015 Old 03-21-2015, 05:07 PM
Quoted: 56 Post(s)
Liked: 27
P5 means it cannot get a signal off the disc. My guess would be laserrot. Sometimes you cannot see it visually by looking at the disc but since you flipped the disc over and it still won't play I believe your players are fine.
post #971 of 1015 Old 03-22-2015, 02:33 PM
originalsnuffy's Avatar
Now that Kurtis has restore my pioneer 703 to its former glory (public thanks) I am considering dubbing some discs to digital. I do have a working dvd recorder. However this converts the PCM to ac3.
Any cheapo suggestions on how to concert discs to digital with uncompressed audio. Looked into a hauppuage but their support told me it converts linear Pcm into AAC or some other compressed format. I would need an external usb box for my htpc. There is no room for an internal card. I have a fair amount of useful software including an older copy of Vegas
originalsnuffy is offline
post #972 of 1015 Old 03-22-2015, 11:42 PM
leev's Avatar
Quoted: 14 Post(s)
Thanks Kurtis. :relaxed:
leev is offline
post #973 of 1015 Old 03-24-2015, 01:43 PM
KBMAN's Avatar
Quoted: 338 Post(s)
Liked: 170
Hey Guys,
Just ressurected my pioneer CLD-1090 which i had an AC-3 mod put in...works perfectly, except I need an AC-3 RF demodulator for it to pass 5.1 (anyone know of a good and cheap source for one of those???)
I also have a DCLD-D701 in perfect shape....has more bells and whistles, but I just want to watch Star Wars 1995 'Faces' LD's for the best video and audio....and YES, I know that these discs do NOT have DD I just want to keep one player for the unaltered trilogy!
Many thanks in advance!
KBMAN is offline
post #974 of 1015 Old 04-07-2015, 12:27 PM
fireproof710's Avatar
Originally Posted by KBMAN View Post
Hey Guys,
KBMAN, there are a few yamaha AC3 RF demodulators up on eBay at the moment. I think they were asking around $60 or so for a starting bid.
You could also search for the Yamaha DDP-1 which is a bulky unit that decodes the AC3 and outputs it as 5.1 separate channels (it has 6 RCA jacks on the back of it) that you can patch in to a home theater amp if it has a multi channel input. That's what I ended up doing on my setup because I had the shelf space for a bulky unit, my amp had a multi channel input, and I didn't want to pay the high price that the compact demodulators usually go for
Red Dolittle likes this.
fireproof710 is offline
post #975 of 1015 Old 04-24-2015, 12:22 PM
Rich86's Avatar
Quoted: 136 Post(s)
Liked: 67
Just for fun . . . . nostalgia . .
We watched the new "101 Dalmations" (the original animated version) Disney blu-ray the other day. It is a terrific blu-ray set.
Sooooo . . I dragged out my "101 Dalmations" (the Glenn Close/Jeff Daniels version) Disney laser disc this morning to see if it still worked and what kind of quality I would get.
Equipment:
Pioneer DVL-919 combo laser/dvd player
Lexicon LDD-1 AC3 demodulator
Yamaha RX-V3900 receiver
Sony LED HDTV 46"
This title is a THX laser disc with a Dolby AC-3 track. I set the LDD-1 to snag the AC3 track and pass it on, and the receiver to decode it.
The audio was perfectly fine.
The video came across the S-VHS connection to the receiver. The receiver was set to upconvert it to 1080p and pass it on to the TV via hdmi.
The video was surprisingly good . . surely not full HD quality, but probably comparable to an upconverted DVD (although I did not do a direct comparison to test that).
The laser disc played perfectly all the way through (no laser rot or problems of any kind) and all the equipment performed perfectly.
A long-time audio/video addict!
Rich86 is offline
post #976 of 1015 Old 04-25-2015, 08:03 AM
trailblazer's Avatar
Quoted: 32 Post(s)
Equipment:
Sony LED HDTV 46"
Interesting that you get a watchable picture via your HDMI connection to your TV. I have a Pioneer DVL-909 laser/DVD player and run it through a Marantz AV8003 Pre Tuner processor up to an Epson PowerLite Pro Cinema 1080 projector. If I try watching a LD via the the up converted component or HDMI out connection on the Marantz to the projector I only get a black & white picture. If I use either composite or S-Video out, I get a color picture. The picture via composite (composite looks cleaner than S-Video in my set up) looks fine albeit very soft compared to an HD picture. If you look at the picture via either component or HDMI, the picture looks a little better upconverted from the LD, but it is hard to tell since I cannot get any color to display from the LD to these output connections to the projector. If anyone has any ideas how to get the color info from a LD to the component and HDMI connections, I would love to hear about it. When operating the DVL-909 with a LD playing the unit looks like it shuts color off from outputting from the LD player to the Marantz component and HDMI outputs and if you play a DVD, than the player shuts the color off on composite or S-Video.
trailblazer is offline
post #977 of 1015 Old 04-25-2015, 08:28 AM
Rich86's Avatar
Quoted: 136 Post(s)
Liked: 67
The component connections on the Pioneer DVD/Laser Disc combo players are intended for DVD playback only and cannot provide color from a laser disc (since laser disc video is basically composite on the media). Since I only use the DVL-919 for laser disc playback, I leave my player set to output video via S-Video and let the receiver upconvert to 1080p HDMI. That's as good as laser disc playback gets on my system.
Assuming your Marantz AV8003 is capable of upconverting an input S-Video signal to 1080p HDMI output, try unplugging the component cables from your DVL-909 to the Marantz in order to get proper color from your laser disc playback via S-Video. I find if the player senses the component connections are active, color disappears from laser discs.
Rich86 is offline
post #978 of 1015 Old 04-25-2015, 08:55 AM
Quoted: 32 Post(s)
My Marantz is setup to up convert a 480i signal to component and HDMI. I will try your suggestion of pulling the component cables from the DVL-909 and see if color appears on the LDs from composite or S-Video.
Thanks for the info.
post #979 of 1015 Old 04-25-2015, 03:40 PM
Quoted: 56 Post(s)
Liked: 27
The component output in the DVL series has confused too many people, Laserdisc is recorded in a composite format so even running composite to the next source may produce the best result. DVD is recorded in a component format and had to be down-mixed to form the S-Video or composite outputs for DVD. I still feel if the S-VHS tape format had never came out laserdisc would have never had the S-Video outputs, the early players didn't have it. Marketing is a wonderful thing and S-VHS was trying to say it was the best format with sharpness. Laserdisc is a composite recorded so find out if your TV or receiver does a better job than your player making the S-Video. After you find out the TV does a better job then I'll let you know that internal to the player is creates Y/C signals for the S-Video output and then recombines them to form the composite on the higher end players except for the CLD-97 Elite. TV's or separate scalers just plainly performance extra magic to the composite signal when separating it to Y/C signals, if you output the S-Video to the TV or separate scaler then it skips the special separating process and usually does not look as good. I cannot answer how well the receiver does. Try both composite and S-Video then you the one that looks best to you.
post #980 of 1015 Old 04-26-2015, 03:33 PM
Quoted: 32 Post(s)
I found that the composite output is cleaner looking than S-Video. In my setup the S-Video was noisy compared to the composite. So I am running it out via composite.
post #981 of 1015 Old 04-27-2015, 08:01 AM
Quoted: 32 Post(s)
I tried your suggestion and pulled the component cables from the unit and can now get up converted LD picture output via component (480p) or HDMI (1080p) to the projector in full color.
Thanks for the info
post #982 of 1015 Old 04-27-2015, 05:30 PM
kucharsk's Avatar
Quoted: 1444 Post(s)
Liked: 783
Basically it comes down to which device has the better comb filter, your LD player or your display.
Back in the day the advice was always to try both composite and S-Video and use the connection that gives you the better picture.
kucharsk is online now
post #983 of 1015 Old 04-27-2015, 06:13 PM
Rich86's Avatar
Quoted: 136 Post(s)
Liked: 67
Thanks for the info
I'm glad it worked out for you. If you do any critical comparisons of s-video vs. composite (connections from the LD to your processor) pq now that color is working for you, I'd be interested. I have had mine connected via s-video forever and as I posted was quite pleased with my viewing and listening experience results recently with a Disney THX/AC3 laser disc. I rarely watch LDs anymore (I rarely watch DVDs anymore either) and switching between composite and s-video connections between the player and my receiver is a pia for me, but if you tell me there is a dramatic difference, I just might try it anyway.
Rich86 is offline
post #984 of 1015 Old 04-28-2015, 01:18 PM
Quoted: 32 Post(s)
I originally had s-video for the longest time connected to my laser disk player until one day I just wanted to see what composite would look like. I was really surprised that in my setup, the composite looked better that the s-video output. What I mean by that, when using s-video I found the picture to be noisy vs a smoother picture from the composite output whether I output to the projector from the processor via 480p component or 1080p HDMI. With that said, there is only so much that you can do to improve a 480i video onto a 100 inch screen projection.The laser disk picture is very soft compared to a Blu-Ray, especially if you zoom into a widescreen presentation. For up converting DVDs, I use my OPPO BDP-83 Blu-Ray player which does a very good job.
post #985 of 1015 Old 04-28-2015, 06:37 PM
Rich86's Avatar
Quoted: 136 Post(s)
Liked: 67
Thanks for the info. Getting at the wires is a pain, but I may do it sometime just for fun to further experiment with LD playback upconverted via my Yamaha receiver. I never use my DVL-919 for DVD playback. I still have a Sony upconverting to hdmi player in my system rack & if I want quality upconversion, I use my Toshiba HD-A35 for that task.
Rich86 is offline
post #986 of 1015 Old 04-07-2016, 03:38 PM
JRTrautschold's Avatar
All,
I need to tweak up my Pioneer CLD-D501 LD player. I've been working on the mechanicals and have all of that working nicely now after replacing a few parts. So now I need to do some electronic adjustments. I do have a copy of the CLD-52 Service Manual for these players; however, this manual does not include main board and audio adjustments. It refers to Service Manual ARP2458. I've searched and search for this manual and haven't found it anywhere. The Pioneer website does list it but says it's no longer available. Anyone know where to get a copy? Thanks.
Right now I'm specifically looking for how to set up tracking. I know where the adjustment is but you can't get to the pot when the disc is loaded! There must be some fake out procedure of some sort to adjust this without having a disc loaded. Frustrating!
John Trautschold
Retired from CBS-TV Engineering
JRTrautschold is offline
post #987 of 1015 Old 04-07-2016, 04:02 PM
Originally Posted by JRTrautschold View Post
All,
Ok - I'm an idiot. It turns out that ARP2458 IS included with the manual I have - it's just in a totally different section of the manual! Yikes! So that solves that problem, but now I still need to figure out hot to tweak it. If anyone has suggestions or has done a full alignment on these devices, I'd appreciate your input. Thanks.
John Trautschold
post #988 of 1015 Old 04-08-2016, 02:25 PM
Quoted: 56 Post(s)
Liked: 27
You really just need to follow the service manual, The focus servo has highest effect for staying locked on CAV LDs, tracking servo for CLV LDs. The tangential and tilt will show crosstalk noise if out of adjustment..
post #989 of 1015 Old 04-26-2016, 11:47 AM
Liked: 0
CLD-D99 problem
Dear All,
My beloved CLD-D99 went dead on me after a power outage, the standby light is no longer on. I checked the fuse (as per several google hits) and it is intact, I can't imagine what could be wrong, but really hope I can salvage this unit. The fuse was 2A T-fuse at 250V, the unit has a US type plug and a voltage selector in the back.
The tragedy is, it is my second D99 to go in a power outage - the previous one was in another country and I did not expect this problem to happen in Europe, and yet.... - and I kept the other unit for spares. The local Pioneer service center in Indonesia said it was not the fuse but they do not have the spare part needed for repairs. Yes, I know, should definitely have used a power surge protector.
Any fix or recommendation would probably save two units. Please tell me something can be done!
-D-
dixie82 is offline
post #990 of 1015 Old 04-26-2016, 02:10 PM
Quoted: 56 Post(s)
Liked: 27
You need to find a repair shop that can actually debug a switching power supply. Most places just swap out boards and Pioneer no longer stocks older power supplies.
Reply DVD Players (Standard Def)
Pioneer , Pioneer Brand , Pioneer Electronics
