Need Help! Denon 3930ci problem/question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-02-2011, 01:51 PM - Thread Starter
jeffkad's Avatar
Just got a new TV and have a problem. I also have been revisting my old settings on the 3930ci. Couple of things I need help with:
1) Playing DVD concert video and have a lip sync problem going with new HDMI to TV connection (never had HDMI before). I go hdmi direct from dvd to tv, but dvd audio goes out to Sunfire pre/pro via digital cable. I have no problem when using component video cable. How do I fix this?
2) If I am using my pre/pro for all speaker settings (distance, delay, etc), I assume I do not need to do this within Denon as well? So should I just set all levels to zero?
Appreciate any help with these issues. Thanks...
jeffkad is offline
Reply DVD Players (Standard Def)
