Issue With Momitsu V880 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-29-2011, 04:21 PM - Thread Starter
rglater's Avatar
I have a DVD-V880 dx that I have never gotten to work properly and wonder if it might be my stupidity or hardware.
I can get sound but no video no matter what method I try to connect (component, composite, S-Video, etc.) to my Sharp LC-52SB55U Full HD 1080p.
Currently I only have composite connection available without taking the TV off the wall or getting a fiber optic scope as all the other connections are almost against the wall.
I doubt I have anywhere near the current firmware. If downloading firmware would help then I do need to be able use my Mac to do so (I have seen download instructions for exe files and that won't work.
Thanks much. It would be nice to watch my small collection of Asian market DVDs.
Richard
rglater is offline
post #2 of 2 Old 03-12-2012, 12:04 PM
Rockmodenick's Avatar
I have only used it in HD with an HDMI output, and it does a much better job of upsamping to HD resolution than the nice sony HDTV. I believe you will need to use the HDMI, I'd recommend putting a ladder or stand in place and moving the TV just off the wall on to that to get access.
Rockmodenick is offline
Reply DVD Players (Standard Def)
