AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   DVD Players (Standard Def) (http://www.avsforum.com/forum/18-dvd-players-standard-def/)
-   -   Denon DVD-2200 has broken transport case (http://www.avsforum.com/forum/18-dvd-players-standard-def/1357975-denon-dvd-2200-has-broken-transport-case.html)
PrgSkidmark 09-02-2011 03:07 PM
My unit was vibrating terribly. I picked it up and something was rattling inside. So I opened it up, and there was a black piece of plastic about 1 inch long floating in there.
I took the screws off the top of the transport cover, and found what the broken piece went to the transport case, or housing, which has metal top, and looks like plastic sides that fold around the back of the metal. The back corner of plastic broke off.
Should I glue it? It probably will not hold.
Should I replace the housing, or transport? The fact that I have a separate Blu-ray player, and this is just my CD player, I'm hesitant to spend any money. But, I know some people replace transports with better ones, and I did have an initial investment in this unit.
Can anyone recommend replacement transports, and where to buy?
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
