Denon Link Cable - AVS Forum | Home Theater Discussions And Reviews
Old 10-21-2011, 03:20 PM - Thread Starter
arftech's Avatar
Quoted: 160 Post(s)
Liked: 127
Where can I find a Denon link cable at a reasonable cost? Or could a simply use an ethernet cable. If that is the case, will the ethernet cable be straight through or crossover?
Thanks All
Al F
Oppo UDP-203, Anthem AVM50V 3D Pre-Pro, Krell KAV-500 3 Channel Amp, Adcom GFA-535 2 Channel Amp, Cary Audio 306/200 CD Player, Emotiva Stealth DC-1 DAC, Oppo HA-2 DAC/Amp, Hifiman HE-500 Headphones, Audeze EL-8 Headphones, Westone UM 50 Pro in ear monitors, Apple PowerBeats 3, MacBook Pro, Apple iPad Pro, Sony XBR65X930C, Sonus faber Luito Towers, Sonus faber Luito Monitors, Sonus faber Smart Center Channel, REL T2 sub, Sony SWF-BR100W Wireless Subwoofer for 930C
arftech is offline
Old 10-21-2011, 04:58 PM
SoNic67's Avatar
Liked: 29
My original Denon Link cable looks like it is a CAT5E or 6 STP (shielded) straight patch cable. I think that AudioQuest has a Cat5E that some people reported it worked with the DLIII. Mine came with the DVD-2930.
http://www.musicdirect.com/p-228-aud...net-cable.aspx
SoNic67 is offline
