Multi disc DVD players - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-05-2012, 09:18 PM - Thread Starter
olz442's Avatar
WHat is the best kind of Multi disc DVD player to buy? I want one that will hold at least 100 DVD's. I would really like to buy one with a RF remote but according to the posts, they are no longer available. I would appreciate any input on makes/models and where to buy one. Thanks!
olz442 is offline
post #2 of 3 Old 03-05-2012, 10:29 PM
Tulpa's Avatar
Liked: 61
No one makes them anymore (and none had an RF remote, ever.)
Sony, Pioneer, Onkyo, and Kenwood made them. Onkyo and Kenwood's were likely rebadges of the Pioneer, which held 300 discs. Sony was the last one to build one and the only one with upscaling. It held 400 discs. The others would be several years old at this point and finding a decent one would be tough.
eBay is your best bet. Amazon might have a few, too.
Sony's BDP-CX960 was the last one built, and does DVD and blu-ray. You MIGHT even find a new in box or open box one. The older one is the DVPCX995. DVD only. A new one of those would be a miracle.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #3 of 3 Old 03-08-2012, 03:50 AM
EJ
EJ's Avatar
I have a CX960. If you look in the player thread, both the 960 and the "ES" model have been discontinued and are becoming very hard to find.
Former USSB uplink operator.
EJ is offline
Reply DVD Players (Standard Def)
