Converting to RF signal - AVS Forum | Home Theater Discussions And Reviews
Old 03-15-2012, 01:45 AM - Thread Starter
olz442's Avatar
I have a Sony CX995V 400 Disc player and would like to put it in a closet. What or where can I buy the equipment to do this if it can be done? I am a rookie and know nothing about this stuff. Thanks for any replies.
olz442 is offline
Old 03-15-2012, 12:30 PM
Liked: 61
You need something like this:
http://www.crutchfield.com/S-mPQSq7B...om_remote.html
If you have an RF remote, the receiving unit will pick up the signals, convert it to infrared, and beam it to the Sony component.
Try the remote forum here. Those guys are way more knowledgeable about what to get.
http://www.avsforum.com/avs-vb/forum...aysprune=&f=93
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
