Samsung 1080p9 - AVS Forum | Home Theater Discussions And Reviews
Old 03-22-2012, 02:00 PM - Thread Starter
Demolitions's Avatar
I have a Samsung 1080p9 Dvd Player, i am looking into buying a External harddrive and wanted to be sure that i can use a Usb Powered Hard drive. I can't seem to find any info on the power output on the usb connector. I have read other threads that say External harddrives do work but they were 3.5" self powered Harddrives. I Would Like to maybe Piece together my own Portable Harddrive so I know What The Dive/Specs Are im getting, So i guess the question is has anyone here Been able to use a usb powered (no Y connector as there is only 1 usb port) External Harddrive on the samsung 1080p9 Dvd Player Successfully, and What Brand/Size/Usb1.1/2/3(I say 3 as the connector can be backwards compatible). Any Help Would Be Appreciated.
Well i have contacted samsung and asked the Question#1 "Can i use a usb powered harddrive on the samsung 1080p9" Question#2 "What is the power output on the usb Port"
Answer#1 "No You cannot use a usb powered harddrive on the samsung 1080p9" Anaswer#2 "There is no power output at all Through the usb port".
Dissapointed That they could not tell me the exact power output from the usb port as there has to be some for usb flash drives to work. So i guess they are just to lazy to look up that information for us.
And so the question still remains. If anyone has tried a usb powered harddrive on the samsung 1080p9 please let us know.
Demolitions is offline
Old 08-01-2012, 09:17 PM - Thread Starter
Just wanted to let everyone know, I purchased a samsung M2 portable 500GB HDD on sale from newegg. smile.gif about $54.99.
I had to download a samsung program to format to fat32 as windows would only show NTFS or eXFAT. mad.gif
The software was pretty simple to use and worked well and the quick format option took maybe 35sec.
Plugged the hard drive into my samsung 1080p9 and BAM powered up no problem and played movies smoothly.
I don't understand why samsung lied about power output and being able to use a portable hard drive with the 1080p9.
This Harddrive was for sale when i wrote Samsung to ask about it. So they should have known.
Oh Well, there you have it folks. Working great !!
Old 08-02-2012, 06:14 AM
SoNic67's Avatar
Liked: 29
FYI: FAT32 will limit the file size to maximum 4GB... (actual value is 4GBytes - 1 bytes). Not very good for HD video.
SoNic67 is offline
Old 09-07-2012, 10:38 PM - Thread Starter
I have a work around for my Movie backups that are 5-9GB in size, So i can split them with out losing any quality smile.gif . And i can adjust the file size appropriately for any new backups i make.
Not one movie stutters or skips. Only downfall is the file type limitation.
