Sony MDP-740D Problem Reading LD's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-29-2012, 04:27 AM - Thread Starter
MV_Cinema's Avatar
Hi Everyone
Just got e Sony MDP-740D Pal/NTSC Player, really nice player. But has a problem, when i insert the LD, it recognizes the LD, the display lights up and doesn't read the disc.
This Player was low used, should't be like that.
I have the possibility to buy a new laser pickup for it. Do you guys think that's the problem?
MV_Cinema is offline
post #2 of 5 Old 03-29-2012, 10:35 AM
Josh Z's Avatar
Quoted: 2137 Post(s)
Liked: 1434
Unfortunately, the real problem here is that it's a Sony Laserdisc player. Mechanical breakdowns are par for the course.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #3 of 5 Old 03-29-2012, 11:27 AM - Thread Starter
MV_Cinema's Avatar
Hi
Do you think it can be fixed?
post #4 of 5 Old 03-29-2012, 02:43 PM
Josh Z's Avatar
Liked: 1434
Would probably cost you more to fix this one than to replace with a better Pioneer model.
Josh Z
Josh Z is offline
post #5 of 5 Old 03-30-2012, 01:53 AM - Thread Starter
MV_Cinema's Avatar
Hi
What the player does is:
The laser and the motor work. If I insert a laserdisc, the motor starts and you can hear that the unit tries to focus. Then it stops, but the display shows "LD"
The unit has very little usage...Can that be a simple Laser cleaning?
Reply DVD Players (Standard Def)
