DVD & LaserDisc Audio - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 05-26-2013, 03:46 PM
pioneer1070's Avatar
Actually note that the DTS audio and AC3 is 20bit/96K not 16 bit. I can post a picture to back this. Ive seen a lot of wrong info...some people need to go do their home work.
pioneer1070 is offline
post #32 of 37 Old 05-26-2013, 03:52 PM
Being a musician and actually using expensive high end audio gear... the analog or the digital audio on Laser disc is far better than DVD. The compression on dvd blows period.
post #33 of 37 Old 05-26-2013, 04:43 PM
Roger Dressler's Avatar
Quoted: 1872 Post(s)
Liked: 1004
I can assure you that there is no such thing as 96 kHz AC-3.
Since the LD format is 44.1 kHz PCM, there is no option for DTS 96/24 at all. It can only work on a 48 kHz-based system, like DVD.
As for 16 or 20 bits, this is a bit of irrelevance when it comes to lossy codecs. The actual wordlength is quite reduced by the encoder, to a few bits per band. The quantization noise remains inaudible because of gain scaling, bandlimiting and masking.
The DSPs that do the decoding used to be graded as being accurate to 16, 20 or 24 bits, below which was uncertainty or noise. Back in the mid '90s it was not yet common for DSPs to use extended precision calculations (>16 bits), but anything made in the last decade or so easily qualifies as the "20-bit" or better performance, so Dolby long ago dropped the decoder chip grading criteria.
The AC-3 encoders, from day 1, have always treated the source PCM as if it were 24 bits. The only thing that has changed over the years is that while DD on LD was 384 kbps, DVD raised it to 448 kbps, and now Blu-ray usually uses DD at 640 kbps.
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #34 of 37 Old 05-27-2013, 02:40 PM
My mistake it was 20 bit/48k thank good its not 16/44.1
post #35 of 37 Old 05-27-2013, 02:46 PM
Was confusing it with my combo player that does 20/96k
post #36 of 37 Old 10-30-2013, 07:40 PM
herb_vogel's Avatar
ok i give, what is a BBE Sonic Max
herb_vogel is offline
post #37 of 37 Old 11-04-2013, 08:15 PM
JoeHZ's Avatar
JoeHZ is offline
Reply DVD Players (Standard Def)
