VHS to DVD Copyright - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-02-2012, 08:00 PM - Thread Starter
wg_rebel's Avatar
Hi, A buddy of mine has several hundred VHS Movies that he would like to copy onto an DVD.. I have an JVC Machine that will do
dubbing in both directions.. It is an DR-MV99B.. When I try to dub from VHS to the DVD, the Machine states that this VHS is Copyright
protected and will Not Dub it.. I have heard that there are some older machines they will do this job.. Maybe some older Panasonic's..
Can anyone advise me on this and provide Name and Model numbers??
All help is appreciated..
Tnx, WG
wg_rebel is offline
post #2 of 3 Old 10-02-2012, 08:01 PM - Thread Starter
wg_rebel's Avatar
I forgot; my buddy does Not have a Computer..
wg_rebel is offline
post #3 of 3 Old 10-03-2012, 05:47 AM
jjeff's Avatar
Quoted: 778 Post(s)
Liked: 278
http://electronics.mcmelectronics.com/?N=&Ntt=video+stabilizer
Note most combo recorders will not allow you to insert such a filter between the 2 sides of the combo, not sure about your JVC.
Older (pre EZ model) Panasonics will, otherwise you'll need a separate VHS player or separate DVDR and use your combo to just play the tapes.
The general wisdom is( considering the quality of VHS) is it's just not worth converting tapes you can easily purchase or rent on DVD, but it's your call smile.gif
jjeff is offline
Reply DVD Players (Standard Def)
