Oppo 983H disc tray - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-07-2012, 11:43 AM - Thread Starter
Kensmith48's Avatar
Quoted: 53 Post(s)
I've had a 983H for a few years and now the tray only opens, but won't close when the button is pushed. Anyone know if there is a fix for this or do I need Oppo to repair?
Ken
Kensmith48 is offline
post #2 of 4 Old 11-07-2012, 12:47 PM
moxie1617's Avatar
Give Oppo a call or send them an email. They may be able to walk you through a procedure to fix the tray. A long time ago I had a similar problem and they were able to resolve it on the phone. If not, remember that Oppo has a flat rate repair policy. I don't know what it is right now for the 983 but should be around $60.
moxie1617 is offline
post #3 of 4 Old 11-07-2012, 09:26 PM - Thread Starter
Kensmith48's Avatar
Quoted: 53 Post(s)
Thanks for the info. I sent Oppo an e-mail and they said the 983 has an alignment error and that I should turn the player off after removing any disc and then lift the front of the player several inches and then drop it to try and bring it back into alignment. I guess I'll give it a try tomorrow. Can't hurt.
Ken
post #4 of 4 Old 11-17-2012, 03:28 AM - Thread Starter
Kensmith48's Avatar
Quoted: 53 Post(s)
Thought I'd update for those with the same problem. I followed Oppo's instructions and it worked great. I dropped the front edge once and now everything works as intended.
Reply DVD Players (Standard Def)
