My PC's DVD player won't play some of my DVDs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-20-2012, 11:14 AM - Thread Starter
GAMESHARQ's Avatar
It's a relatively new computer (bought it about a year and a half ago). It plays some of my DVDs but not others. They're all factory DVDs, nothing that I burned myself.
When I put the DVDs in, it makes noise like it's trying to read the disc, but nothing happens and eventually it just stops trying after a few moments.
Any ideas what the problem could be?
GAMESHARQ is offline
post #2 of 7 Old 12-20-2012, 11:17 AM
Louquid's Avatar
Liked: 38
Have you tried going to "My Computer" and manually double clicking the DVD drive to make it play?
Louquid is offline
post #3 of 7 Old 12-20-2012, 11:20 AM - Thread Starter
GAMESHARQ's Avatar
Yes. When I do that, it says there is no disc in the drive.
post #4 of 7 Old 12-20-2012, 12:05 PM
Louquid's Avatar
Liked: 38
Is it an HP by any chance? I've had this very issue a few times with failing disk drives on HP laptops. Only ever on HP laptops did it happen like this.
At first it was interrmittent, then it happened with everything I put in it. Until one day it simply stopped trying to even read my disks.
This may not be what your problem is though.
Louquid is offline
post #5 of 7 Old 12-20-2012, 12:07 PM - Thread Starter
GAMESHARQ's Avatar
Yea, it is an HP (AIO) and it's been an ongoing problem for quite awhile actually. I always thought HP was a good brand, but maybe I was wrong. Not sure which brand computer I'll get next now.
post #6 of 7 Old 12-20-2012, 12:30 PM
Louquid's Avatar
Liked: 38
HP is a pretty good brand. It has it's problems just like any other brand, but no more frequent I don't believe. Their laptop drives just seem to have a short lifespan.
I hear good things about Lenovo and Asus. But a quick fix would be to get a USB DVD drive. $12 to $20 on amazon should do it. Can hold you over until you're ready for a whole new PC.
Louquid is offline
post #7 of 7 Old 12-23-2012, 10:39 PM
Cyclone82's Avatar
Some times i have the same problem with my HP from 2009. It always ends up being contaminants on the disc or the laser needs cleaning. Earlier in the year i thought it was stuffed but then i got it working again. I used one of those cleaning discs the otherday and it worked well.
Also you might need to install Slysoft AnyDVD if its region issues.
Cyclone82 is offline
Reply DVD Players (Standard Def)
