Pioneer HLD-X0 laserdisc player problems, help required. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-11-2013, 02:39 AM - Thread Starter
dokworm's Avatar
Liked: 25
I posted this in the other long thread, but there isn't much activity there these days, so....
I have an X0 player that though well packed obviously had trouble during shipping.
At first the tray/door wouldn't open. I pulled it apart and got that sorted.
Now the problem appears to be that the laser is too close to the disc.
The disc starts to spin up, after a second or two I hear the laser hit it. I can see fine marks on the disc where it hits.
I then get a P5 error.
I was getting a U1 error when I first put it together.
Without a disc in the laser moves freely up and down the rail, and the light comes on then off.
Any ideas, or anyone have a service manual? The HLD-X0 was a mongrel to get apart.
DON'T feed the troll.
dokworm is offline
post #2 of 15 Old 01-11-2013, 06:39 PM
Kurtis Bahr's Avatar
Quoted: 48 Post(s)
Liked: 25
The servo's cannot properly lock. There should be a plastic ring on the lens so it will not damage the disc. Lens tapping is a common servo trying to lock issue. The pickup is not too close, the servo is raising the lens to try to get a lock on the disc.
Kurtis Bahr is offline
post #3 of 15 Old 01-14-2013, 06:18 PM - Thread Starter
dokworm's Avatar
Liked: 25
Thanks Kurtis.
That makes sense as the disc clears the laser assembly until that point.
How would I go about trouble shooting this?
dokworm is offline
post #4 of 15 Old 01-16-2013, 05:19 PM - Thread Starter
dokworm's Avatar
Liked: 25
The problem was actually that the entire laser block was crooked in the sled. Removing one of the machine screws allowed it to fall back into place. Replacing the screw and it is all now nice and square.
Reassembled it all, the player now turns on for about 20 seconds, and then just switches itself off again.
I wonder if I messed anything up while poking around.
dokworm is offline
post #5 of 15 Old 01-17-2013, 04:30 PM - Thread Starter
dokworm's Avatar
Liked: 25
Pulled it apart and re-assembled it all, it now works and plays discs.
However they come up garbled and in black and white, barely watchable. I'm guessing it needs to be re-aligned?
dokworm is offline
post #6 of 15 Old 01-17-2013, 05:51 PM
Quoted: 48 Post(s)
Liked: 25
You still have an issue getting the servo to lock properly. There are a lot of adjustments on the board on the bottom under the pickup mechanics. You would need to follow the service manual with the adjustments. With a NTSC LD you should be getting color in the picture if you have any lock of signals. I have only played MUSE LDs after the NTSC portion is working properly.
post #7 of 15 Old 01-21-2013, 05:02 PM - Thread Starter
dokworm's Avatar
Liked: 25
Thanks Kurtis, I have had no luck finding a manual. I'm guessing if the mechanical alignment is still out, then it would be difficult to get a servo lock. I barely get a picture at all and the picture drops out completely every couple of frames.
If anyone has an X0 service manual, I am happy to pay to have it professionally scanned or copied, plus pay for the time etc. involved to get it to a scanning place etc.
There is no-one in Australia that can service the X0, so I am kind of stuck unless I can get hold of a manual.
I'd be happy to translate it into English as well.
dokworm is offline
post #8 of 15 Old 03-02-2013, 09:22 PM
tinyvoice's Avatar
You are making a lot of laserdisc addicts jealous about even having an X0. Have you tried StereoManuals.com--if they have an owner's and/or service manual. They mail it almost anywhere.
tinyvoice is offline
post #9 of 15 Old 03-06-2013, 07:54 PM - Thread Starter
dokworm's Avatar
Liked: 25
I ended up purchasing a service manual, so far no luck with fixing it, but I will keep at it!
dokworm is offline
post #10 of 15 Old 03-23-2013, 08:20 PM
tinyvoice's Avatar
Was away for a while--but did you ever get the X0 running? Feel silly even commenting, as Kurtis knows a whole lot more about repairing LD players than I do, but just wondering.
post #11 of 15 Old 03-27-2013, 04:45 PM - Thread Starter
dokworm's Avatar
Liked: 25
No, I still haven't got the thing going. If it wasn't so heavy I'd send it to Duncan, but freight to and from the US makes it not feasible.
dokworm is offline
post #12 of 15 Old 03-28-2013, 04:09 PM
Quoted: 48 Post(s)
Liked: 25
You could always take the bottom off and make a false bottom and reduce it's weight. I've asked people to do that for me when they wanted to reduce the weight and save on shipping.
post #13 of 15 Old 05-08-2013, 08:19 PM - Thread Starter
dokworm's Avatar
Liked: 25
Thanks Curtis, I was thinking about that the other day. The base plate is incredibly heavy, we have a 30kg limit for OS freight here, it may just bring it in under that if I put an aluminium plate on there instead.
Thanks for the tip!
-Peter
dokworm is offline
post #14 of 15 Old 08-07-2013, 09:35 PM
DLux247's Avatar
Just was curious if you ever got your player working?
Dustin
LG OLED 55EG9100 | Samsung PN51D8000 (DEAD)
Pioneer VSX-1120-K | PS3slim | AppleTV4
Polk Audio | RC85i | RC60i | RM202 | PSW10
DLux247 is offline
post #15 of 15 Old 08-10-2013, 12:09 PM
tinyvoice's Avatar
Think this may have been sent to the wrong individual, if it was meant for my information. Do not have an X0, or an interest in acquiring one at this time, although like you, I am located in the Lone Star State.
Reply DVD Players (Standard Def)
