I need help with only getting black and white picture. - AVS Forum | Home Theater Discussions And Reviews
Old 01-27-2013, 05:41 PM - Thread Starter
jlpowell84's Avatar
Quoted: 1620 Post(s)
Liked: 715
I'm trying to help someone get a their dvd player to work correctly. He has a samsung 720p tv and a Standard Pioneer dvd player from 2004. He has it hooked up from the dvd player to the tv via red, green, and blue rca's. He is getting sound and picture just fine. But the problem is the picture is black and white. His vcr gives sound and color just fine. Advice?
jlpowell84 is offline
Old 01-27-2013, 07:09 PM
Kurtis Bahr's Avatar
Quoted: 49 Post(s)
Liked: 25
Have him check the DVD setup. Video output should be selected to be component.
Kurtis Bahr is offline
Old 01-28-2013, 05:47 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Or he could just try composite cables. He's not going to HD out of a standard DVD player anyway so no need to use component.
joed32 is offline
Old 02-06-2013, 07:38 AM
SAM64's Avatar
Liked: 78
It really sounds as if he's got the blue and green cables switched on one or both ends
Then he wouldn't get an image at all.
Sounds like he has component plugged into a composite input...there was no mention of audio cables, yet he is getting sound.
SAM64 is offline
