Sony DVP-C670D DVD/CD Player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-28-2013, 03:39 AM - Thread Starter
Davecon1973's Avatar
Hi guys,
i was hoping I could get some help, I brought a DVD player home from Australia and it is set to region 4.
I was looking to change it to region 2, Sony have said they cannot do it as it impacts their licence?? however this means it can be done.
Does anyone know how this is possible???
Davecon1973 is offline
post #2 of 2 Old 03-28-2013, 03:40 AM - Thread Starter
This was their actual reply....
Thank you for contacting Sony support. In regards to your Sony DVD changing regions.
Sony United Kingdom Ltd will not authorize or become involved in any modifications to our range of DVD players which are designed and marketed in this country to play Region 2 discs only. Whilst we are aware that modifications are carried out to make our players multi-region, any problems which may occur as a direct result of this will invalidate the Sony European Guarantee and will not be supported by Sony.
Reply DVD Players (Standard Def)
