DVD player Pioneer DV-410 V - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-15-2013, 06:41 AM - Thread Starter
blues546's Avatar
My DVD player was earlier upgraded by firmware 3.1 for DV-410 V and now i upgrade with firmware for DV-420 V 2.4 and I changed the numbers as it is firmware for 410 to fit. DVD player upgraded that firmware and it works, but now I want to put it back to the firmware 3.1 for DV-410 V and when I put the disc with the firmware the DVD shows CD cannot be read. What should I do? Thanks.
blues546 is offline
post #2 of 5 Old 04-27-2013, 11:23 AM
Hkan's Avatar
Reset the player
--> turn it off
--> press and hold the STOP button and then press stand by/On button.
--> It's the players button you should use.
PioneerFAQ
@Twitter
Has "everything" for your Pioneer!
!!We need your support!!
Hkan is offline
post #3 of 5 Old 04-28-2013, 11:33 AM - Thread Starter
blues546's Avatar
I tryed it, nothing changed. dvd is answering the same. Thanks.
blues546 is offline
post #4 of 5 Old 05-04-2013, 11:50 AM
Hkan's Avatar
Did you change the name of the firmware to suite the name of the firmware you have on it now?
PioneerFAQ
@Twitter
Hkan is offline
post #5 of 5 Old 05-05-2013, 06:11 AM - Thread Starter
blues546's Avatar
I changed DV-420 Firmware V 2.4 - YKF9930A to YJB8A31A (Firmware number 3.1. for DVD 410 V) Thats the firmware i have on my dvd now. I tryed to upgrade it with YJB8A31A firmware 3.1 but dvd answered CD can not play.After i saw your response i checked in the dvd options for the name of the current rom version, but it was a different name than i thought. It was YKF9930A and after that i changed the name of firmware YJB8A31A to the name of the current rom version and after that CD was accepted and i managed to upgrade my dvd. Now my dvd's rom version is YJB88A13A and everything is working fine like it did before this adventure..on the 420 firmware subtitles were bigger but it missed the darker background of the sutitles when the picture on the tv is white if there were more black in the background of the subtitles it would be ideal . Thank you for helping. smile.gif
blues546 is offline
Reply DVD Players (Standard Def)
