I Need DVD player with aluminum face that's not a DVD-HD841 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-06-2013, 07:59 AM - Thread Starter
ChopperCharles's Avatar
I need a DVD player that plays SACD, DVD-A, and decodes DTS internally and outputs it to analog 5.1 outputs. It must have an aluminum face, like the Samsung DVD-HD841. The 841 however does not decode DTS internally, it only passes it out the optical port. (I have an 841 now, and I need to replace it with something better)
It is also necessary that I can disable the front speaker and subwoofer inside the DVD player, so that those channels will be mixed back into the front channels on the analog outputs.
I'm using it for music only. I have it hooked up to my vintage Pioneer quadraphonic system, which has all solid aluminum faceplates.
I'd like to keep it under $150. Preferably more like $100.
Thoughts?
Charles.
ChopperCharles is offline
Reply DVD Players (Standard Def)
