HLD-X9 or MSC4000 Picture Issue. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-17-2013, 04:41 PM - Thread Starter
dxklone's Avatar
Has anybody had the same problem?
My set-up is consists of a Pioneer HLD-X9 connected to a Sony MSC-4000 decoder using Chord Prodac VEE3 Digital Coaxial Cable for reading Muse.
The decoder is connected to a Pioneer KRP-500A plasma TV using Chord Component leads.
When Playing Muse discs I get splashes of colour seeping thru in the scenes like faces turning Green and Red and Blue splashes of colour all thru the film.
This slightly disappears only in dark scenes.
I have changed various cables but same results.
Could the fault be with the MSC-4000 not being able to lock and hold the muse signal or could there be a fault with the muse playback feature of the HLD-X9.
When playing standard laserdisc’s with S-VHS leads bypassing the decoder. I get a perfect picture. Can anybody help.
Gus
dxklone is offline
post #2 of 4 Old 06-17-2013, 06:31 PM
Kurtis Bahr's Avatar
Quoted: 48 Post(s)
Liked: 25
The MSC4000 can output different types of signals, RGB or a couple different component type signals. There is a button on the right front that provides the menu to select the type of output signal. Make sure that is correct.
Kurtis Bahr is offline
post #3 of 4 Old 06-17-2013, 07:32 PM - Thread Starter
dxklone's Avatar
Thanks for your response,
Yes I have tried the RGB but this was worst . I got a better image using YPbPr.
dxklone is offline
post #4 of 4 Old 06-18-2013, 05:46 PM - Thread Starter
dxklone's Avatar
dxklone is offline
Reply DVD Players (Standard Def)
