PLAYING A MOVIE IN DVD PLAYER THROUGH A USB PORT---PLSS URGENT HELP-----PLSSS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-21-2013, 02:05 AM - Thread Starter
Manikantt's Avatar
MY DVD PLAYER IS PAGARIA DVD PLAYER WITH USB PORT .I BROUGHT A SANDISK PENDRIVE RECENTLY AND TRYING VARIOUS METHODS TO PLAY A MOVIE IN A DVD PLAYER THROUGH MANY FORMATS.NO FORMAT WAS WORKING.I ALSO TRIED AVS VIDEO CONVERTER AND CONVERTED VIDEOS BY REDEFINING YHE DEFAULT SETTINGS OF AVS VIDEO CONVERTER.I CHANGED THE SETTINGS IN THIS WAY
VIDEO--
VIDEO RESOLUTION--720 * 480
VIDEO CODEC--MPEG 4(DIVX/XVID COMPATIBLE)
BITRATE --1000
FRAME RATE--30 FPS
AUDIO--
AUDIO CODEC--MP3
SAMPLE RATE--44100 HZ
SIZE--16 BIT
BITRATE--192 KBPS
CHANNEL--STEREO
THIS WAS THE CHANGES I MADE TO AVS VIDEO CONVERTER SETTINGS
AND CONVERTED THE VIDEO AND PLAYED IT ON THE DVD PLAYER USING PEN DRIVE
THE MOVIE IS PLAYING WITH GOOD QUALITY BUT ALL MOVIES WERE STOPPING AND GETTING STUCKED AFTER 10-15 MINUTES
I TAUGHT THAT THE MOVIES WERE STOPPING AND GET STUCCKED BECAUSE OF LONG LENGTH AND CUT THE MOVIES FOR EVERY 20 MINS AND CONVERTED AND PLAYED IT ON THE DVD BUT ALSO SAME PROBLEM ARISED AFTER 2-3 MINUTES
IMPORTANT NOTE--THESE ALL MOVIES PLAYED GOOD ON THE LAPTOP WITHOUT ANY PROBLEM
SO PLEASE CAN ANYONE HELP FOR THE ALTERNATIVE METHOD SO I CAN PLAY MOVIES WITHOUT ANY PROBLEM ON DVD PLAYER USING PENDRIVE
PLEASE HELP
Manikantt is offline
Reply DVD Players (Standard Def)
