Spindle rubber for CLD 2950 - AVS Forum | Home Theater Discussions And Reviews
Old 07-22-2013, 08:29 AM - Thread Starter
smiffy's Avatar
Hi All
I'm in the UK and looking for the spindle rubber for a CLD 2950.The Pioneer part number is VEB1135.
If anyone knows where I can get one I would be very gratefull.
Also does the above VEB1135 also fit the CLDD925 and the CLD D703?
Thanks for any help
Smiffy
smiffy is offline
Old 07-23-2013, 02:56 PM
Kurtis Bahr's Avatar
Quoted: 48 Post(s)
Liked: 25
Are you sure of the part number. The 2950 looks like a CLD-D503 and the spindle motor rubber cushion for that is VEB1237. Pioneer in the US says VEB1135 is no longer available.
Kurtis Bahr is online now
Old 07-24-2013, 10:59 AM - Thread Starter
smiffy's Avatar
Yep
Got service manual here.Def VEB1135.I'll give VEB 1237 a go then.ta
App not replaceable in the D925.You have to get the whole spindle.And don't have service manual for CLD D703 to check that part number
Thanks for the help
John
smiffy is offline
Old 07-24-2013, 05:52 PM
Quoted: 48 Post(s)
Liked: 25
The VEB1237 is the part for the 503/703/704/79/99
Old 07-25-2013, 09:15 AM - Thread Starter
smiffy's Avatar
Thanks Kurtis
I will take the top off the CLD D703 and compare it to the CLD 2950.
I dont think the CLD D925 is replaceable.I think you have to replace the turntablke spindle.
This appears to be pt number VXA2225 but states in manual NSP which I presume means non service part
Smiffy
smiffy is offline
Old 07-26-2013, 09:30 AM - Thread Starter
smiffy's Avatar
Checked the CLD 703
The CLD 703 and 2950 use the same spindle assembly so I guess VEB1237 will fit both
Just having trouble finding the part in the UK
Smiffy
smiffy is offline
Old 07-26-2013, 03:07 PM
Quoted: 48 Post(s)
Liked: 25
I can always buy some for you in the US but they are not cheap, with tax and shipping they are around $20 each. Then add shipping to you
