HDMI and Standard Def (480i) player - AVS Forum | Home Theater Discussions And Reviews
Old 07-27-2013, 01:57 PM - Thread Starter
ThumbtackJack's Avatar
Quoted: 21 Post(s)
I know HDMI cables are associated with HD, but is it better to use it over both S-Video and Composite for the output of SD 480i from a DVD player to a TV -- if the player has all 3 oututs? Thanks.
ThumbtackJack is offline
Old 07-27-2013, 02:36 PM
Selden Ball's Avatar
Quoted: 3046 Post(s)
Liked: 1494
To get the best video quality, it's usually best to send digital data (HDMI). Modern display devices are digital, as is the signal coming from the disc. The player has to convert that digital signal into analog so it can output S-Video and Composite signals. The display device has to reconvert an analog video signal into a digital format so it can up-scale the incoming image to the screen's actual resolution.
However, you have to use an analog video connection to get closed-captioning, if you need or want that. HDMI audio is transmitted during the "Vertical retrace interval", which also is when the closed-captioning text is transmitted. Having one prevents having the other. Closed-captioning text usually is different from the subtitie tracks provided on DVDs.
Selden
Selden Ball is online now
Old 07-27-2013, 11:28 PM - Thread Starter
Quoted: 21 Post(s)
Thanks Selden. I was wondering because I've always heard component video being the recommended output for SD DVD players, being that it splits the colors 3 ways for best picture performance. As much as I've tried to learn about HDMI, I never really saw anything technical about how it aligns the colors (something like component does). Is that because all the colors are stored in the digital information then, since its not an analog cable? Perhaps that is what makes HDMI more accurate than other cables, even for standard def. programming?
Old 07-28-2013, 01:32 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2682 Post(s)
Liked: 1915
HDMI uses "component video" just as component cables do. Both are upgrades over composite and S-Video. There is no reason to prefer component cabling over HDMI in terms of quality.
The industry is killing off component cabling anyway.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Old 07-28-2013, 02:28 PM
gregzoll's Avatar
Liked: 33
Originally Posted by wmcclain View Post
HDMI uses "component video" just as component cables do. Both are upgrades over composite and S-Video. There is no reason to prefer component cabling of HDMI in terms of quality.
-Bill
They already killed it off as of the 2012 models. If you want component these days, it is only for special purpose and you need an adapter for it, that is manufacturer specific. Then add to it, you do not get 720p/1080i/1080p/24.
gregzoll is offline
