Has Pioneer exited the industrial DVD market? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-02-2013, 10:58 AM - Thread Starter
scdiver's Avatar
Good morning,
I have an older Pioneer DVD-V7400 Industrial DVD player, at the office, that no longer works. I decided it was probably time to upgrade anyway, but still need the "industrial" capabilities. I see they have the V5000, V6000 and V8000 listed on their website (http://www.pioneerelectronics.com/PUSA/Professional/Pro-Video) but I can't seem to find them available for sale anywhere!
Anyone out there know if there are new ones coming out, or if I am just going to have to work with consumer crap and spend a fair amount on adapting HDMI to RGBHV?
Jeff
scdiver is offline
post #2 of 6 Old 08-02-2013, 06:18 PM
myoda's Avatar
Liked: 57
Originally Posted by scdiver View Post
Good morning,
Jeff
Having a hard time finding info on the Pioneer products. Could be the end of the line. Perhaps this would work:
TASCAM DV-D01U 1-rackspace DVD Player w/RS-232 Control Port
http://www.amazon.com/TASCAM-DV-D01U-1-rackspace-Player-Control/dp/B000TUEWC8
http://tascam.com/content/downloads/products/78/DV-D01U_tech_doc.pdf
myoda is offline
post #3 of 6 Old 08-04-2013, 05:22 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 284 Post(s)
Liked: 3927
Do you really need a DVD player? Why not use a computer? More versatility with regard to content format and displaying other things.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #4 of 6 Old 08-04-2013, 08:07 AM
myoda's Avatar
Liked: 57
larry
It's possible the OP has some legacy hardware that needs an analog connection.
The tascam has the same output ports and is built like a tank.
Pioneer v7400
back panel:
Tascam dvdv01u
back panel:
He might have to pick up some adapters - the Pioneer had a BNC connection. RCA to BNC needed for the Tascam. Unknown what the other equipment is the DVD player is outputting to.
myoda is offline
post #5 of 6 Old 08-05-2013, 09:40 AM
Moderator
Moderator
Quoted: 284 Post(s)
Liked: 3927
I would think you could still find at least one video card that outputs component video. Maybe not.
larry
post #6 of 6 Old 08-05-2013, 11:01 AM
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
larry
There are also operational concerns. Sometimes you need a simple "put the disk in and play" solution. Computer based DVD and BluRay players are difficult to make simple and reliable. Bootup time is another possible issue in a commercial setting.
Glimmie is offline
Reply DVD Players (Standard Def)
Pioneer Dvd V7400 Industrial Dvd Video Player
