Anyone had this before? Black goo on DVD player - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Hornacho
post #1 of 3 Old 06-22-2014, 01:41 PM - Thread Starter
Liked: 1
Hello! I was just cleaning out my home theater cabinet and noticed a very sticky black goo coming out of the top of my Sony DVD player. It is very hard to get the goo off my hands. It's literally like motor oil. There are no vents on the top... so it looks like it's coming from the back edge maybe?
Is it time to get a new DVD player? The DVD player works fine. Is there anything to worry about safety-wise?
I have seen my audio cables develop a sticky residue over time, but never a black goo.
It does tend to get very hot in the cabinet when I have the system running.
Any advice or info would be greatly appreciated.
Hornacho is offline
post #2 of 3 Old 06-22-2014, 02:27 PM - Thread Starter
Liked: 1
Okay...I think I may have answered my own question. Upon further inspection and cleaning... I think it's just the paint from the DVD player that has melted from the heat of the cabinet. I took a paper towel and wiped it. Lo and behold... the paint is removing.
If someone in the future runs into this... hope this helps!
Chirst Linch likes this.
Hornacho is offline
post #3 of 3 Old 06-23-2014, 03:59 PM
Mark12547's Avatar
Quoted: 712 Post(s)
Liked: 472
That seems odd ... unless the cabinet gets quite warm, and heat could be hard on the electronics.
And you are sure the goo isn't coming down onto the DVD player from above?
My very humble setup:
Spoiler!
Mark12547 is online now
Reply DVD Players (Standard Def)
