Lgdp432h usb dvd helllppp? - AVS Forum | Home Theater Discussions And Reviews
Old 08-03-2014, 02:13 PM - Thread Starter
Liked: 0
Hi there i am new to this forum and im sorry if its in the wrong place but i am desperate for some help
i have bought an lg dp432h dvd player and have been trying to get films to work off my usb stick but to no avail
i am wondering if anybody knows what i should do do i have to change the format of the films i am putting on and if so what to any help would be greatly appreciated thanks aaron
azza261 is offline
Old 08-04-2014, 05:42 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 286 Post(s)
Liked: 4073
Page 7 of the manual lists the file formats supported and the USB stick needs to be FAT16 or FAT32 file system format. If you are trying to play movies with resolution greater than 720x576 then you are probably out of luck.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
