Pioneer DVL-909 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-05-2014, 05:45 PM - Thread Starter
Ozlaserdiscfan's Avatar
Pioneer DVL-909
Hi all,
I picked up a brand new pioneer DVL-909 on eBay from a guy here in Australia a couple of years back, and it has been fine the last couple of years,(it hasn't had heaps of use) but recently it has been making a strange squeak or maybe grinding sort of noise when loading a disc, or when powering down when the mechanism 'parks' it's hard to describe but definately sounds as though something is rubbing in the mechanism. Any one have any ideas what his could be?
Regards Craig
Ozlaserdiscfan is offline
post #2 of 3 Old 08-06-2014, 02:15 PM
Kurtis Bahr's Avatar
Quoted: 48 Post(s)
Liked: 25
Originally Posted by Ozlaserdiscfan View Post
Hi all,
Regards Craig
Remove the top and see if helping lift up the laser mechanism resolves the sound. If it does then buy a new loading belt generic part number SCQ4.0 it is under the tray on the front left.
Kurtis Bahr is offline
post #3 of 3 Old 08-07-2014, 04:57 PM - Thread Starter
Okay, thanks Kurtis, will give it a try
Reply DVD Players (Standard Def)
