Automatically Powering on a Sony DVP-SR510H - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-13-2014, 08:38 AM - Thread Starter
Liked: 0
I have a Sony DVP-SR510H player that is feeding four TV's in a museum setting. Due to the display, the player is difficult to get to and the IR Receiver is also difficult to use with the remote (partially blocked). I have the setting where once powered on, the player automatically plays the DVD but is is possible that once the power receptacle gets power in the morning, for the player to automatically turn on? I have done this with certain TV's and computers, but never a DVD player.
davetf is offline
post #2 of 2 Old 08-13-2014, 11:43 AM
jjeff's Avatar
Quoted: 689 Post(s)
Liked: 245
I believe that would be a function of your DVD and not player. You'd need the player to automatically start playing the main or first title on the DVD player, I've seen this with DVDs but not as a player function, for sure not with Sony players.
Would it be possible to rip or reauthor your DVD? You could reauthor it with something like Shrink and only copy the main title, when powered on the DVD player should automatically start playing that title. Note if your in a commercial setting, playing a copied commercial DVD may not be the best idea but if you always had the original near or on top of the DVD player it wouldn't be like your watching the same title in two different places, kind of a grey area.....
jjeff is offline
Reply DVD Players (Standard Def)
