Question - Whats the best way to hook up an HLD-X0 Laserdisc Player?? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Kurtis Bahr
post #1 of 3 Old 09-01-2014, 05:08 PM - Thread Starter
Jim Parys's Avatar
I have read mixed opinions. Some say composite others say S-video. I can either go through my Yamaha CX-5000 for scaling, my Oppo 105 for scaling or direct to my JVC DILA projector (current 2014 model).
Suggestions by the experts?
Thanks in advance.
Jim Parys is Living the dream...
La Sirena III Theater
Jim Parys is offline
post #2 of 3 Old 09-01-2014, 07:47 PM
Kurtis Bahr's Avatar
Quoted: 42 Post(s)
Liked: 25
The answer varies depending on the equipment you have to use and your preferences. You have to try the different combinations and use the one that looks best to you. People serious about upscaling get more serious equipment like the higher end DVDO units.
Glimmie likes this.
Kurtis Bahr is offline
post #3 of 3 Old 09-02-2014, 11:03 AM - Thread Starter
Jim Parys's Avatar
What is the best scaler one can use. How are the Lumagen verse DVDO units? How do they compare with the built in scaler in my Yamaha CX-5000 or i the Oppo 105
Reply DVD Players (Standard Def)
