Lens cleaning - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-04-2017, 01:21 AM - Thread Starter
TECH198's Avatar
Quoted: 27 Post(s)
Lens cleaning
Do these work best even on DVD players ?
I have a DVD laser lens clearer,, the discs u get at the store, and my Panasonic DVD player refuses a large batch of copied from in-build HD, they previously played ok...
Testing these disks on a Mac DVD with VLC, plays just fine....
The fact thee discs played on previously suggests its not a compatibility issue.
My question is can regular laser lens cleaners also work on DVD players and/or recorders?
To me, there is no proof of specific leans cleaners for specific purposes.. its all to make money. unless there is a better way... AT the end of the day, they all clean the same way.... the lens is physical not different. but i'm wondering if these work at all, or weather i just report to something else.
TECH198 is offline
post #2 of 5 Old 05-04-2017, 09:33 AM
jasonsong's Avatar
Quoted: 488 Post(s)
Liked: 179
Does the brush go all the way? I know some only at certain areas meaning you would have to play the disc all the way to clean the lens.
Why do you need to clean it is what I am asking.
7.2: Yamaha RX-A830 | Klipsch Synergy F30 + C20 + Sub12x2 + Onkyo HTIB Surrounds | Epson HC2040 Silver Ticket 120 inch Grey Screen
5.1: Yamaha RX-V475 | Mirage Omni 550 Onkyo HTIB Center + Surrounds + 12 inch Sub | Samsung 55 inch Smart 3DTV
jasonsong is offline
post #3 of 5 Old 05-04-2017, 10:10 AM - Thread Starter
TECH198's Avatar
Quoted: 27 Post(s)
Because it wont read discs it could previously play ok. I'm not sure what you mean by "Does the brush go all the way"
TECH198 is offline
post #4 of 5 Old 05-04-2017, 10:24 AM
jasonsong's Avatar
Quoted: 488 Post(s)
Liked: 179
Usually these discs have like soft bristles on the lens side so when you play the disc, the lens gets cleaned by the bristles.
I think your problem might be just aging laser emitter.
post #5 of 5 Old 05-04-2017, 03:05 PM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 334 Post(s)
Liked: 6940
That's what I was thinking, also.
Ich bin hier und du bist mein Sofa
PooperScooper is offline
Reply DVD Players (Standard Def)
