Kenwood Entre Technical Discussions - Page 35 - AVS Forum | Home Theater Discussions And Reviews
post #1021 of 1021 Old 04-07-2015, 07:49 PM
James A. McGahee's Avatar
Quoted: 44 Post(s)
Getting Entre back on line after several years out of operation
Originally Posted by James A. McGahee View Post
Thanks! Can anyone else confirm the last firmware, was it 2.0.0.16 or 2.0.0.8?
Still having problems getting my Entre on line.
I am using the originally required Cat 5 Crossover cable with the original USB adapter.
Does it matter which USB slot is used-upper or lower one for the adapter?
Is the crossover cable still necessary with newer receivers?
Is anyone using a new currently available USB adapter?
Mine may not be working even though the light still glows yellowish-orange. I assume it would
still need to be paired with the crossover cable. Right?
If anyone can list the specific fill-ins for the ip address, gateway, etc. that would be the same for everyone (if that is even possible) it would help me eliminate some of the possibilities. Also I have no idea as to my Open Globe user name and password. I have it somewhere but not sure it would even still be appropriate.
Is that something I am going to eventually need to retrieve album, covers, information, etc.?
James A. McGahee is offline
Reply DVD Players (Standard Def)
