Escient FireBall DVDM-100?? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 458 Old 04-30-2004, 07:37 AM
b00bie's Avatar
Phil
So far I have done a lot of setup and very little watching, I would like to check the DTS problem you are talking about, exactly what was happening in your setup, BTW my video (component, interlaced) is perfect I do not see a difference between the picture switching the Fireball in and out, however this morning I hooked up the s-video into the distribution amp and the picture is really soft, I am going to check the cables later on, hopefully I just have a bad one somewhere.
Tom
b00bie is offline
post #182 of 458 Old 04-30-2004, 07:39 AM
chadly25's Avatar
I remember when I first hooked up my unit I was a little disappointed with the IR control. When I took off the film covering the IR receiver it helped but was still not without flaw. If you are looking for the BEST IR method to control the DVDM, you will need to purchase an IR repeater system. To do this simply cover the IR window with some black tape. Install an IR receiver and place it anywhere that is line of sight from your remote. Connect your IR receiver to an IR connecting block. Then hook up a 1/8" mono cable from connecting block to IR 1/8" mini plug on the back of the DVDM. If you have a Pronto that is RF capable, simply get the RF base station and plug in a mono cable from RF base station to IR input on back panel of DVDM. This is how I have mine installed and have never had an issue with control.
chadly25 is offline
post #183 of 458 Old 04-30-2004, 07:42 AM
chadly25's Avatar
Remember Tom, DVD's are made to perform best with component video. The picture won't look as good with S-Video, but it shouldn't also look bad. It should look as good as a DSS broadcast connected with S-Video.
chadly25 is offline
post #184 of 458 Old 04-30-2004, 07:45 AM
Super Moderator
markrubin's Avatar
Quoted: 1039 Post(s)
Liked: 2283
Pyramid IR repeaters work well too: my units are in closets and I use the repeaters for the keyboard
The ultimate solution to this is the LCD Touchscreen: not cheap but it makes the UI much better
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #185 of 458 Old 04-30-2004, 07:54 AM
b00bie's Avatar
Chad
I presently use a rather complex Xantech IR system to control my system, I ran a cable directly from one of my zone amps into the IR IN jack on the back of the fireball with no change in results, which prompted me to ask the question about being able to back up my data, as I beleive that I am going to have to send my unit in to get it repaired.
Tom
P.S. I understand that the output would not be as good on S-video, I am judging the picture by what I used to get from the S-video out of the Kenwood when I had them daisey chained together before the Fireball, this is not a new setup for me , I previosly had all of this functional and distributed throughout my home, the only new component is the Fireball and the great interface, and the quality of the picture is much softer than even the SD output of my satellite receiver which is fed to the same amp.
b00bie is offline
post #186 of 458 Old 04-30-2004, 08:02 AM
pciav's Avatar
Tom,
The DTS issue was on DTS only releases such as Apollo 13, Dragonheart, The Eagles: Hell Freezes Over, & The Bee Gees: One Night Only. The menu comes up to select DTS only sometimes and other times not. Even when selecting the DTS track it defaults to DD 2.0. Going through the menu or using the audio button was also unsuccessful. Without the Escient I am able to select and play these tracks with no problem. Now, you have the Kenwood player, so oyu may not have this problem at all.
Phil C.
"Where does he get all those wonderful toys"
Jack Nicholson as the Joker in Batman
pciav is offline
post #187 of 458 Old 04-30-2004, 09:19 AM
chadly25's Avatar
Tom,
Did you cover the front when you had it connected to the rear of the DVDM? That could be causing a problem. I have had devices not operate properly when they see two identical commands simultaneously.
chadly25 is offline
post #188 of 458 Old 05-01-2004, 09:13 PM
BJBBJB's Avatar
Quoted: 38 Post(s)
Check page 124 in the manual
Thanks B00bie. I actually am one of those strange people that read manuals. However I only glanced at the internet settings page as that was working.
Anyway, found the setting and it works well. Hope you solve your problems.
BJBBJB
BJBBJB is offline
post #189 of 458 Old 05-01-2004, 09:13 PM
BJBBJB's Avatar
Quoted: 38 Post(s)
BJBBJB
BJBBJB is offline
post #190 of 458 Old 06-29-2004, 09:10 AM
DerekFSU's Avatar
Thinking about dropping my Entre and hooking up my Kenwood changers and Kenwood 5900 receiver to the Escient products, everyone still happy? I want to hook it into a multi-room/multi-source system in a house I am building.
B00bie, what do you think having been a Kenwood man?
Go Noles
DerekFSU is offline
post #191 of 458 Old 06-29-2004, 11:04 AM
b00bie's Avatar
Derek
Very happy with mine, I have it hooked up to an Onkyo 989 and I use the zone 2 out into a distribution amp that I send to other rooms in the house, I have IR in those rooms so I can just pick a movie off the list wherever I am and watch it. The DVDM seems to be much more stable than the Entre, and while there is more of a monetary investment to get the same functionality as from an Entre, it is much easier to use and has no down time (so far). You should be able to pick up a used H-40 on ebay, you can use a USB/Ethernet adapter or HNPA to hook it to your network, and I understand it can be upgraded If you need any help let me know.
Tom
b00bie is offline
post #192 of 458 Old 06-29-2004, 08:50 PM
BJBBJB's Avatar
Quoted: 38 Post(s)
Derek,
Like the DVM100 a lot. Can't compare to the Entre as I never had one, but it works well. Found about 90% of my discs, first try. Also nice CCF support. Now if I could only keep my Kenwood DV-5900M reading discs and in service!! But that is another story.
BJBBJB
BJBBJB is offline
post #193 of 458 Old 06-29-2004, 09:00 PM
DerekFSU's Avatar
What do you guys think a good price for an H with the 120gb upgrade may run? How about the M100? If I do not need different MP3's playing at the same time, is there any reason to go for the MP-100?
I heard from Escient today that they are doing some type of music server deal in September that will make the migrating of MP3's from the computer to the player much more reliable and easy. They said it would only require a software update.
Go Noles
DerekFSU is offline
post #194 of 458 Old 07-09-2004, 12:33 PM
chadly25's Avatar
The H units only came as a 40 gig. I wouldn't buy a hacked unit if I were you, that's only asking for problems. The MP-100 won't work with the DVDM-100 because the MP-100 only reads MP3's from an H or E series fireball and the DVDM doesn't have a harddrive to store MP3's.
The software you are speaking of sounds really promising. It allows you to use your computer to not only file share to your fireball, but also control it. Can't wait to take my laptop outside and be able to easily control my music through my outdoor speakers.
chadly25 is offline
post #195 of 458 Old 07-09-2004, 12:42 PM
Super Moderator
markrubin's Avatar
Liked: 2283
Still happy with my DVDM-100 & E-120
post #196 of 458 Old 07-09-2004, 01:51 PM
Lars158's Avatar
I sold my Kenwood Entre a few months back due to a lot of frustration... I now have the DVD-M100 system connected to my Kenwood 5900M's, and it works like a charm!! I also bought an old FB and upgraded the HD to a 120 GB. Works great together with the DVDM100! I am now a happy camper (I was not during my Entre days)!
Lars Berglund
Plano, TX
Lars158 is offline
post #197 of 458 Old 07-12-2004, 11:58 AM
chadly25's Avatar
How did you upgrade? Did you use a golden disc or something?
chadly25 is offline
post #198 of 458 Old 07-12-2004, 04:14 PM
Lars158's Avatar
Yes, there is a way to reformat a new 120 GB HD using a CD on the classic FB... It will install a fairly old version of the SW with the 120 GB partitions. Once the FB is booted up the FB will download the latest sw version - that's it. I got the CD from someone that got it to work on his FB, so it was easy for me. I got a demo FB for $900 at a local dealer, so with the 120 GB upgrade I got the full system for less than $1200 in total. Pretty good deal! It works very well with the DVDM-100.
Note: to my understanding there is no easy way to upgrade the new 40 GB FB. The upgrade CD I used will only work on the classic FB.
Lars Berglund
Plano, TX
Lars158 is offline
post #199 of 458 Old 07-12-2004, 07:16 PM
DerekFSU's Avatar
Are there any REAL reasons to get the new fireball instead of the upgradeable old one?
Go Noles
DerekFSU is offline
post #200 of 458 Old 07-12-2004, 07:30 PM
Lars158's Avatar
Not really to my understanding... the main new feature on the new FB is the built in ethernet card. On the classic you need to use a USB to ethernet converter if you have it on a network (e.g. connected with the DVD-M), but that's no big deal. Other than that I don't know about any improvements over the classic FB.
Lars Berglund
Plano, TX
Lars158 is offline
post #201 of 458 Old 07-13-2004, 07:02 AM
b00bie's Avatar
Derek
You also have the flexibility of using HPNA on the classic if you want to.
Tom
b00bie is offline
post #202 of 458 Old 07-13-2004, 02:40 PM
chadly25's Avatar
The one difference between the two could possibly be the next generation of computer interface software. At this time it is up in the air whether or not it will work on the H units. I sure hope it is. Pipeline is good for what it is, but there could be some definate improvements.
chadly25 is offline
post #203 of 458 Old 07-13-2004, 05:27 PM
b00bie's Avatar
I can't believe that Escient would abandon the H series given the way they currently support thier discontinued products when they introduce this new software. I think given the market that they appeal to this would not do them too much good. I gotta tell you Chadley I do not find the Pipeline software to be good at much, maybe casual editing, but when it comes to transferring files it is really poor at best.........
Tom
b00bie is offline
post #204 of 458 Old 07-13-2004, 09:01 PM
chadly25's Avatar
Well I have heard both stories. I for one really hope that we get the update too, but to be safe, I would buy an E rather than an H at this point. I'll keep my fingers crossed too.
chadly25 is offline
post #205 of 458 Old 08-11-2004, 07:20 PM
BJBBJB's Avatar
Quoted: 38 Post(s)
Greetings,
My DVM-100 and Kenwood 5900 combination is going to the escient "disc image" screen saver while watching a movie.... even though nothing has paused the movie. It appears random, and has happened about 5 or 6 times during a showing of one of the Star Wars flicks.
I wonder if anyone else have seen this behaviour. Of course I immediately suspect the ever-tempramental Kenwood 5900, but don't want to jump to that conclusion.....
BJBBJB
BJBBJB is offline
post #206 of 458 Old 08-11-2004, 09:41 PM
Lars158's Avatar
Originally posted by BJBBJB
Greetings,
BJBBJB
I have never seen that problem (I am using 2 5900M's with my DVDM-100). Sounds strange...
Lars Berglund
Plano, TX
Lars158 is offline
post #207 of 458 Old 08-12-2004, 06:09 AM
b00bie's Avatar
I have never seen this either, I have a 5900 and two 5050's hooked up to mine. There is an option in the setup menu to adjust the amountt of time or even turn off the screen saver, I don't see what bearing it would have on your problem but try changing the timing, if that doesn't do it you can always call tech support they are great.
Tom
b00bie is offline
post #208 of 458 Old 08-13-2004, 05:34 AM
BJBBJB's Avatar
Quoted: 38 Post(s)
Thanks. However now the DVM-100 will not control any transport controls (stop, play, etc.) on the changer, although it will power it up/down, and the dvd menu commands work. I am going to try changing the wires to see if that helps, but I suspect something has gone bad...
If I use the direct changer remote, the transport commands still work.
BJBBJB
BJBBJB is offline
post #209 of 458 Old 08-13-2004, 06:07 AM
b00bie's Avatar
The transport control is sent over the 1/8 cable, the other funcions you mentioned are sent through the RS-232, I would check that cable first....Did you try the old standby the reboot you know when all alse fails with a PC power cycle.
Tom
b00bie is offline
post #210 of 458 Old 08-13-2004, 06:12 AM
b00bie's Avatar
Sratch that last post, I went and did a little test, the DVD menu stuff is sent on the 1/8 cable...can you select a disc from the menu and the changer cues it up to play?
Tom
b00bie is offline
Reply DVD Players (Standard Def)
Escient Fireball Dvdm 100 Dvd And Music Manager
