Very Fresh Firmware List for Panasonic! (RP91 and XP unit discoveries!!) - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 1153 Old 04-13-2004, 07:17 PM - Thread Starter
Sango's Avatar
Quoted: 16 Post(s)
It could of been non-anamorphic encoded DVDs which could be the culprit.
Sango is offline
post #452 of 1153 Old 04-13-2004, 07:19 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
Originally posted by QuicknDirty
..... somehow screwed up- they're generally "older" movies...ie Sling Blade, Highlander, etc.
Aaah I think we've found your problem. Older released DVD's like Slingblade and maybe Highlander were released in the non-anamorphic (i.e. non-16x9) format.
For these type of discs to look right, you'll need to watch them in Expand mode on your Mits. Every newer widescreen DVD release from the past couple of years should be fine in Standard mode.
Sam S is offline
post #453 of 1153 Old 04-13-2004, 07:20 PM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
me & Sango are thinking alike (at the same time)
Sam S is offline
post #454 of 1153 Old 04-13-2004, 08:47 PM
geocab's Avatar
Quoted: 51 Post(s)
Liked: 59
Ahhhh, that's it! Cool, I'm glad it wasn't a problem with your player. Unless, of course, you didn't check the....oh, never mind!
geocab is offline
post #455 of 1153 Old 04-13-2004, 08:51 PM - Thread Starter
Sango's Avatar
Quoted: 16 Post(s)
I chatted with QnD private. It appears that his discs are NOT encoded properly and the player is not reconizing the anamorphic format when it's inserted. The previous firmware didn't have the issue but with the new one, it doesn't like it. He will contact the manufacture reguarding the issue.
However, other anamorphic discs he does have are ok! =)
Sango is offline
post #456 of 1153 Old 04-13-2004, 11:22 PM
MarkMac's Avatar
I've got an RP82 and I upgraded from 282 to 302 tonight. No problems, and it took about 5 minutes. Without measuring, I'd say PQ may be slightly improved, but layer changes seem to be quicker. Thanks Sango!
MarkMac is offline
post #457 of 1153 Old 04-14-2004, 04:42 AM
dcheesi's Avatar
So does that mean I should hold off on upgrading my RP56? I do have a few older movies, including a version of Highlander.
Too bad, I was really hoping it would help with some other issues...
EDIT: The Highlander dvd is definitely NON-anamorphic, and playback on my (non-upgraded) RP56 in "16:9 display" mode results in a 4:3 picture, which would get stretched on a wide display. I assume by "encoded wrong" you mean the AR flags that get sent to the TV? In progressive mode I have to set AR manually on my TV anyway; this would only be a problem for me in interlaced mode. Or am I missing something?
dcheesi is offline
post #458 of 1153 Old 04-14-2004, 08:03 AM
cupofjoe's Avatar
Sorry, if the answer to this question is obvious, but where can I find the download for the RP-56 firmware. I can't find it on my newserver.
Cheers
cupofjoe is offline
post #459 of 1153 Old 04-14-2004, 08:48 AM
Diode1's Avatar
All models are within the same file.
From page #1 link #2
http://www.compendiumarcana.com/rp82v302.rar
Diode1 is offline
post #460 of 1153 Old 04-14-2004, 10:19 AM - Thread Starter
Sango's Avatar
Quoted: 16 Post(s)
dcheesi:
I'm not sure which Highlander he was using but he said the DVD player would use to go widescreen automatically, but now it's it's showing in 4:3 with the blackbars to make a 16:9 image. So it's some to do with the player not picking it up right. You could still upgrade if you want.
Sango
Sango is offline
post #461 of 1153 Old 04-14-2004, 10:41 AM
mrwilson's Avatar
I didn't think the RP56 would pillarbox non-anamorphic material like the RP91 does.
mrwilson is offline
post #462 of 1153 Old 04-14-2004, 05:37 PM
Jeff Aguilar's Avatar
Quoted: 16 Post(s)
Liked: 36
Send a message via Yahoo to Jeff Aguilar
Thank you for the update. I updated my Denon 1600 with no problems. Again, thank you so much.
Jeff Aguilar
Jeff Aguilar is offline
post #463 of 1153 Old 04-14-2004, 06:13 PM
gtaylor74's Avatar
It doesn't. The scaling is a function of the RP91's Genesis deinterlacer. The 56 of course uses the Faroujda which has no scaling capabilities.
gtaylor74 is offline
post #464 of 1153 Old 04-15-2004, 06:18 AM
goddahavit's Avatar
Hey, I just want to shout out a thank you to all here and sango, the firmware, I just upgraded my 2 xp30's and it went fine,
It definatly helped my black levels on my l200u projector, I do not know why, but it is definatly better
only problem I ran into so far (and I do not know if it was this way before, as I never watched it) was goodfellas, A friend gave me a dvd to watch, all it says on the back is a special widescreen matted version enhanced for widscreen tv's, when I watch it is stretched , I found out by switching my pc priority to normal, it fixed it but gave it black bars on the sides as well asa the top, ???
I am asuming it is matted all teh way around, and when I have my projector set to pc wide it streteches it out to the start of the pic??
anyway, others I sampled looked great, gladiator, lotr, awsome,
thanks all!!
1 quick q?? what is the black level setting in the setup? it has lighter and darker, I can't see much of a differance, in the 2 I just set it to darker.
again, thanks sango, this helped my situation greatly
goddahavit is offline
post #465 of 1153 Old 04-15-2004, 06:50 AM
Sam S's Avatar
Quoted: 212 Post(s)
Liked: 106
"Goodfellas" is mislabled on the packaging. It is not 16X9 enhanced i.e. anamorphic. So I would expect you to have black bars on all sides. You'll have to use some sort of Zoom setting on your display to watch it in the normal proportions.
I don't believe this setting has any effect in 480p mode. I could be wrong. When in doubt, use the "Darker" setting.
Sam S is offline
post #466 of 1153 Old 04-15-2004, 07:25 AM
goddahavit's Avatar
thanks, Sam
I did finally decide it was something with he dvd, everything else looked fine, but just after the upgrade I was nervous...
thanks for the info on the black level....
1 more stupid q, I have never used dts, I do not know If I am missing something, do I have to switch audio soundtracks to enable it, or is thier something else? my reciever does have a dts decoder, ??
post #467 of 1153 Old 04-15-2004, 09:16 AM
Vtb2's Avatar
"The PQ thing may just be a placebo effect or The Matrix Revolutions is just a much better transfer than many of my other discs"
I have a denon 1600 and since doing the upgrade, i can say without a doubt that picture quality has improved. I watched Matrix revolution the other night, and it looked awesome. This is one of the better transfers out there, the skin tones are unbelievable, excellent detail, this movie looks close to hd on my hitachi 46F500 as you can get with dvd.
Vtb2 is offline
post #468 of 1153 Old 04-15-2004, 09:32 AM
greeno's Avatar
Liked: 25
It is pretty well known that the Matrix series DVD's have transfers that are about as good as can be done. No EE anywhere. OT, I watched Kill Bill Vol. 1 again night before last and that transfer is damn good too, BUT the text overlays have EE. So close, yet so far...
Best,
jeff
greeno is offline
post #469 of 1153 Old 04-15-2004, 11:32 AM
kungster's Avatar
Besides the on-screen menu, does the firmware do mpeg decoding/other key functions responsible for picture quality?
I have the RP56, and have tried the firmware - as reported by others, the menu and changing chapters/titles is faster. Picture quality also appears subtly improved with better details. Would the picture quality enhancements be because of changes to the mpeg decoder?
kungster is offline
post #470 of 1153 Old 04-15-2004, 03:34 PM - Thread Starter
Sango's Avatar
Quoted: 16 Post(s)
Most possibly, it could of modified the mpeg decoder chip's code to improve the image quailty.
Sango is offline
post #471 of 1153 Old 04-15-2004, 05:42 PM
Jeff Whitford's Avatar
Well I tried it using the last link & alcohol 120. I inserted the disc in the player and it says no play. Now what?
Jeff Whitford is offline
post #472 of 1153 Old 04-15-2004, 06:06 PM
psloan's Avatar
Use the software listed in the first post. Worked fine for me this afternoon. My xp30 is now running the latest firmware.
psloan is offline
post #473 of 1153 Old 04-15-2004, 06:29 PM - Thread Starter
Sango's Avatar
Quoted: 16 Post(s)
Jeff, just curious which unit are you updating?
Sango
Sango is offline
post #474 of 1153 Old 04-15-2004, 06:34 PM
An RP56. I am a complete idiot when it comes to computers. So maybe I didnt unzip the file or whatever. I am so confused and stressed out that I cant eeven think straight
post #475 of 1153 Old 04-15-2004, 06:40 PM
RelDudeGOP's Avatar
okay i have an xp30
i'm confused...
can someone tell me in one post how to
1) check my current firmware
2) where to download the new one from
3) How to install the new one
i've read the whole post and can't find a overall answer
thanks all!
Comcast: GET HD-Net!
RelDudeGOP is offline
post #476 of 1153 Old 04-15-2004, 07:13 PM - Thread Starter
Sango's Avatar
Quoted: 16 Post(s)
Werid, link by Jeepfun is dead. I'm removing that from my start post.
RelDude, reguarding all of your questions, the answer is right on right on the start thread so there shouldn't be any confusion.
Bascially just download the rar file and then extract using WinRar. Assuming BW is already installed, setup the settings as mentioned on the start thread. Then select the BWT image which is that long M name, then make sure the burning settings are set, write at 4x and you're set to go.
Sango
Sango is offline
post #477 of 1153 Old 04-15-2004, 07:35 PM
RelDudeGOP's Avatar
what's BW?
post #478 of 1153 Old 04-15-2004, 07:40 PM - Thread Starter
Sango's Avatar
Quoted: 16 Post(s)
BW aka BlindWrite
BR aka BlindRead
Sango is offline
post #479 of 1153 Old 04-15-2004, 08:07 PM
how do you extract?
post #480 of 1153 Old 04-15-2004, 08:32 PM
FrankS's Avatar
Originally posted by Jeff Whitford
how do you extract?
Jeff,
I'm not trying to offend you but from all your basic questions you are asking, this project may be a bit beyond your abilities and it would probably be best to see if someone can send you a CD (paying them of course for their time/postage).
FrankS is offline
Reply DVD Players (Standard Def)
