Momitsu V880 WoW! - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 260 Old 05-09-2005, 05:13 AM
popechild's Avatar
Quoted: 13 Post(s)
Hmm...
I just checked the Extremephono site and noticed a note about conflicting remote IR codes with Pioneer receivers. Is this the same problem as with the Bravo D2? I'm trying to find a good non-HDCP dvd player, but I've got a new Pioneer VSX-1014 - do all 3 of the v880 versions have this remote problem?
popechild is offline
post #182 of 260 Old 05-09-2005, 05:29 AM
Toonces T. Cat's Avatar
Originally posted by popechild
Hmm...
The conflict in the IR codes is not just with the Pioneer receivers. The Momitsu V880 codes also conflict with Pioneer LD players as well.
-Toonces
"I wasn't born in Texas, but I got here as fast as I could."
-Archie Whippet
Toonces T. Cat is offline
post #183 of 260 Old 05-09-2005, 06:01 AM
popechild's Avatar
Quoted: 13 Post(s)
Is it with all 3 v880 models? I read somewhere that the codes on the v880N might be different and not conflict?
post #184 of 260 Old 05-09-2005, 06:13 AM
Sorry, but I do not know the answer to that one. It's not really a big deal for me as I only have the LD issue and the power on/off codes do not conflict on the LD player. The only time it has been an issue is when I am transferring an LD to DVD on my ILO recorder. One, or another, of the Pioneer codes turns the Momitsu on. I just cover the IR receiver on the Momitsu with a small flat piece of plastic and it blocks the signal...It's a minor irritation, but certainly nothing worth dumping the otherwise excellent Momitsu over.
-Toonce
-Archie Whippet
post #185 of 260 Old 05-09-2005, 06:51 AM
wblynch's Avatar
Quoted: 45 Post(s)
Liked: 24
The V-880-N does not interfere with Pioneer codes
The V-880 and V-880 Deluxe do interfere with Pioneer codes
wblynch is offline
post #186 of 260 Old 05-12-2005, 12:46 PM
mdray's Avatar
Quoted: 16 Post(s)
Hello.
The Momitsu website has new firmware for the 880DX.
It's version 1.1.17 and it adds new zoom modes, panning, and very helpfully, an XY scaling mode, which means you can size the picture to any aspect. This is one feature that helps me loads!
mdray is offline
post #187 of 260 Old 05-12-2005, 01:33 PM
wblynch's Avatar
Quoted: 45 Post(s)
Liked: 24
Originally posted by mdray
Hello.
Wow, thanks for the heads up.
Although you don't state that it will work with the original V-880 I think I'll give it a go anyway and see what happens.
BTW, can you post a link to that download site?
Thanks, Bill
wblynch is offline
post #188 of 260 Old 05-12-2005, 01:42 PM
loopy's Avatar
Thanks, Bill
I already posted this info earlier last night. I just update the old thread I had created
http://www.avsforum.com/avs-vb/showt...hreadid=482712
loopy is offline
post #189 of 260 Old 05-12-2005, 01:50 PM
wblynch's Avatar
Quoted: 45 Post(s)
Liked: 24
Thanks Loopy !
wblynch is offline
post #190 of 260 Old 05-12-2005, 02:03 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Loopy let us know how the upgrade goes on the v880.
rwestley is offline
post #191 of 260 Old 05-12-2005, 02:08 PM
loopy's Avatar
I have the deluxe, update went smoothly. I just got in 3 new netflix movies, so I will check things out tonight hopefully. I'm wondering if the new loader firmware provides smoother layer change, although TBH the v880dx for the most part has a pretty unnoticeable layer change, I really only notice it from time to time. You gotta use nero to burn the loader firmware, they packed it in .nrg format instead of .iso
loopy is offline
post #192 of 260 Old 05-12-2005, 02:24 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
I wonder if the firmware would work on the non deluxe model?
rwestley is offline
post #193 of 260 Old 05-12-2005, 02:25 PM
loopy's Avatar
probably not. the deluxe has bigger memory capacity for firmware.
loopy is offline
post #194 of 260 Old 05-13-2005, 01:43 AM
Dave Tv's Avatar
There is a "read me" in with the firmware that shows some non-dx versions might be able to upgrade.
Are there any non-dx units with 1.1.13 or higher?
Momitsu DVD player - V880-DX Firmware update version ver1.1.15 Release2
Important Note!
* This English-language firmware version is V880-DX ONLY.
* To verify if you have V880-DX: Please go to Setup Menu > Initial Steting> > Firmware version 1.1.13*
If your V880 is loaded with ver 1.1.13 frimware or avove, you can use this update.
If your V880 is loaded with ver. 1.1.12 or below, please DO NOT upadte with this version.
* After update, please use "Video" button to select Video output if there is no video on the screen.
* In order to get the best performance of video quality, Please do not connect SCART and component out put at the same time.
Verify from S/N number:
V880 S/N MT239Axxxxx
V880DX S/N MT93A4xxxxx
Dave Tv is offline
post #195 of 260 Old 05-13-2005, 02:42 AM
satgeek's Avatar
I had loaded ver. 1.1.14 on my non-dx V880, don't know if higher versions will load.
BTW, has anyone tried the new loader firmware thats available on the dx firmware page?
satgeek is offline
post #196 of 260 Old 05-13-2005, 04:31 AM
vjren's Avatar
Higher versions will not load or work correctly on the V880 (non dx) I tried 1.13 and 1.14 but settings are lost or it doesn't load firmware al together.
Anyone any more luck?
vjren is offline
post #197 of 260 Old 05-13-2005, 05:59 AM
Grumps's Avatar
OK,my V880-DX has the original firmware (ver.1.1.13) it was shipped with and never has been updated. Should I load all updates from ver.1.1.14, ver.1.1.15, ver.1.1.15 release 2, ver.1.1.17, and ver.8X6Q (05-05-05) 1 at a time or just the last update?
Grumps is offline
post #198 of 260 Old 05-13-2005, 08:10 AM
loopy's Avatar
grumps: just go directly to 1.17. when they release new firmware they always include the fixes and additions from the previous version, so there is no need to install each firmware (they will just overwrite each other anyway)
loopy is offline
post #199 of 260 Old 05-13-2005, 08:32 AM
Grumps's Avatar
Will do - and if any one can screw it up nobody can do it like I can.
Grumps is offline
post #200 of 260 Old 05-13-2005, 08:54 AM
loopy's Avatar
if you have it available, plug your momitsu into an uninterruptible power supply before you update it. also, if you need to follow the onscreen insctructions, don't use DVI, cuz for some reason it won't display on the DVI
loopy is offline
post #201 of 260 Old 05-13-2005, 09:04 AM
Grumps's Avatar
Have it set with DVI and to digital output on TV - looks like I gotta do some changing around before i attempt it - before I do it do you think it's worth the update? Am i glad I had a lunch break and oh shi% it's Friday the 13th too.
Grumps is offline
post #202 of 260 Old 05-13-2005, 09:08 AM
loopy's Avatar
I update without anything on my TV, you just gotta know at which point to hit the play button so it can start the firmware flashing. and yes, if you're running the original firmware you probably should update both
loopy is offline
post #203 of 260 Old 05-13-2005, 10:33 AM
Grumps's Avatar
went like a charm - now if i can find out how to use it - I need a firmware update for myself - On, off, eject, close, pause, play, is my original firmware now to get zoom etc. is going to take some getting used too.
Grumps is offline
post #204 of 260 Old 05-13-2005, 10:35 PM
Dave Tv's Avatar
I've got a Mits 65807 and have this 880DX hooked to it via component cables to the HDTV input. (no dvi on this set)
Whenever I set it for 1080i, and the 880's splash screen comes up, I get this video tearing effect across the middle of the screen that reminds me of macro-vision.
When I play DVD's I have to start them in 480P mode to navigate the menus, etc., then switch to 1080i after the movie starts. If I don't go thru this sequence the 880 will dump the video, and go to 'blue screen'.
Anybody else experience this?
I've tried setting the macro-vision on and off, and set the region code to my location, but this does not change the 1080i video tearing/dumping problem.
Dave Tv is offline
post #205 of 260 Old 11-30-2005, 05:43 PM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
Originally Posted by kwatkins View Post
I got a new DVD burner and using Nero software have no problem copying 4.7gig dvds and playing them on the Momitsu. However, I can't play double layer DVDs. Is this a limitation of the player?
Kirk
Finally got DVD+R DLs to play in this thing...here's all the details:
Verbatim DVD+R DL (#95166)
Nero 7.0.0.0
burned ISO image at 4x
Sony DRU-810A automatically set book type to: DVD-ROM
Momitsu V880 with latest firmware (ver.1.1.12, 5-26-04)
Theater 1: LG OLED55E6P 4K TV, Samsung UBD-K8500 UHD Blu-ray player, Oppo UDP-203, Dune HD Solo 4K
Theater 2: Epson 5020UB (won on AVSForum!) on Elite Sable 16:9 100", Oppo BDP-83 / 93 (ISO firmware) / 103D (CFW), Dune Base 3.0 / Smart units, Darblet, Sony MDR-DS7500 Wireless Surround Headphones & Onkyo TX-SR707
fatherom is offline
post #206 of 260 Old 01-05-2006, 09:15 AM
mflagg's Avatar
Howdy,
I own the V880 DX model, and love it, on my projector.
I now have a new 37"lcd flat panel for the bedroom, and want another dvd player. I am happy with the component upscaling output. I was wondering if there is anything better that has come out?
You can't mess with a good thing. I will probably try hunting down a V880 DX for sale from someone.
~~Later Mike
mflagg is offline
post #207 of 260 Old 03-09-2006, 05:39 PM
ellsworth's Avatar
mflagg,
I have been looking for a dvd player that upconverts specifically via component (I have a Sharp
9000 fp and need 720p). The only other current player I have come across is the NeuNeo and the reviews I've seen aren't nearly as favorable. Do you or anyone else know of any other good player that does this? Also, did you consider the 880N?
There is always something better.
ellsworth is offline
post #208 of 260 Old 03-09-2006, 08:45 PM
greeno's Avatar
Liked: 25
Component upconversion: zenith 318 with older firmware, lg dvb418 with latest dvb531 firmware from lg-canada. Not sure what else.
jeff
greeno is offline
post #209 of 260 Old 03-10-2006, 05:06 AM
ellsworth's Avatar
Thanks Jeff, I'll check those out.
post #210 of 260 Old 04-23-2006, 10:13 PM
sdg72's Avatar
Has anyone modified the v880 or v880dx for SDI output ? The reason I am asking is because I have a V880 and love the performance of it, but would like to use a DVDO HD+ with the SDI input for the best possible picture quality. Or is this DVD player not a good candidate for this type of modification.
Home Theaters, once you get started there is no end. :)
sdg72 is offline
Reply DVD Players (Standard Def)
