Denon 3910 Owners Thread - Page 251 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #7501 of 7513 Old 03-25-2014, 04:21 AM
Tom Grooms's Avatar
Quoted: 133 Post(s)
Liked: 209
The 3910 will connect to a Pioneer Elite firewire input. I ran that setup for years
Hear me now, Listen to me later....
Tom Grooms is offline
post #7502 of 7513 Old 03-26-2014, 06:21 PM
Dr. Venkman's Avatar
I understand that this has/is being done, however I simply cannot get a connection that works. I just acquired the denon and am wondering if a firmware update could solve this problem.
How can I determine which device is not working to achieve the connection?
Thanks to all
Dr. Venkman is offline
post #7503 of 7513 Old 03-26-2014, 06:45 PM
JohnGZ28's Avatar
Thanks to all
Do you have another receiver you can connect it to? If not take it to a friend's house and connect it there to see if it works. Have you tried a different connection method just to confirm that it works at all?
JohnG
JohnGZ28 is offline
post #7504 of 7513 Old 01-04-2016, 10:12 AM
DonPedro34's Avatar
Hi 3910 fans,
Its been ONE whole year since i last logged in.
I got a personal question from Ron_Phelps (Jan 2015 - yes 2015!), i cant answer you - because the forum system doesnt allow it - i haven't posted enough to answer private mail.
Anyway here is what Ron wrote:
I seem to remember that u replaced your laser in the 3910 - I have tried to contact Michidragon for some pics of pt 2 of the assembly procedure to no avail - can u at least show me where the solder blob(s) are that have to be removed ?
Here is a Picture of the old laser (with two red arrows)
Cheers
Per
DonPedro34 is offline
post #7505 of 7513 Old 01-05-2016, 03:58 AM
Ron_Phelps's Avatar
Originally Posted by DonPedro34 View Post
Hi 3910 fans,
Cheers
Per
Per
Thx for your reply - so are these the solder blobs that need to be removed then ??
thx
Ron
Ron_Phelps is offline
post #7506 of 7513 Old 01-05-2016, 03:59 AM
Ron_Phelps's Avatar
Denon 3910 laser
Hi 3910 fans,
Cheers
Per
Per
thx
Ron
post #7507 of 7513 Old 01-05-2016, 11:58 AM
DonPedro34's Avatar
Originally Posted by Ron_Phelps View Post
Per
thx
Ron
Hi Ron,
In the image you see 4 blobs, because the 2 Solder-bridges has already been removed (what you see is two x two half circles).
When you install it, you have to remove the old defect Laser from the 3910'er first (obviously) - then mount the new one, and when you have attached all cables again, only then you can unsolder the 2 blobs.
Careful! Use a low temperature solder iron if possible and do not touch the blobs for more than 3-4 seconds - otherwise you could heat damage the flex cable or the plastic housing behind the flex cable.
Yes, it's a plastic housing.
And use a solder-wig to unsolder - i did that - worked nicely and fast.
Cheers
Per
post #7508 of 7513 Old 01-05-2016, 01:21 PM
JBaumgart's Avatar
Quoted: 133 Post(s)
Liked: 81
I still have my 3910 but am no longer using it. Looks and works like new but I choice not to reinstall it when I got a new cabinet and chose just to go with my Oppo blu-ray player. The Denon is in the original box and I have the remote, manual, etc. Is there still a market for these?
Vizio M80-C3
Denon AVR-X7200WA
Odyssey HT-3 Plus
Infinity Prelude MTS
HSU ULS-15 MK2 DualDrive
Oppo BDP-83
JBaumgart is offline
post #7509 of 7513 Old 01-05-2016, 02:24 PM
HTPCat's Avatar
Quoted: 700 Post(s)
Liked: 438
Yes, many are sold on auction site and for the past year the prices have gone up to average above 300 for a well cared for unit.
HTPCat
"I have a need to feed the hole with more Audio & Video toys"
HTPCat is offline
post #7510 of 7513 Old 01-05-2016, 02:48 PM
JBaumgart's Avatar
Quoted: 133 Post(s)
Liked: 81
Thanks, HTPCat.
Vizio M80-C3
Denon AVR-X7200WA
Odyssey HT-3 Plus
Oppo BDP-83
post #7511 of 7513 Old 03-18-2016, 12:11 AM
Mandrax's Avatar
Repost here, but a bit of a conundrum:
I love my DVD-3910, it has served me well, but IEEE-1394 and DL3 doesn't do much for the newest components, so...
What's the best bet for an upgrade for a DVD-3910? After 12-or-so-years of great service, upgrades keep obsoleting the audio functions I need it for.
When I had a Pioneer Elite flagship, I got great Multichannel DSD, MLP streamed right into the processor via Firewire / I394. But good luck finding s 4k Proc with that.
When I replaced that with a super high-end flagship, Denon Link III did the same thing, trouble free, all processing in the receiver with great processing and DACs.
Now that I've moved to a 4K/60hz ingest/processing chain, are there any reasonably-priced DVD or Blue-Ray playerd that successfully output real, non-downsampled DVD-Audio and 2/5-ch SACD DSD to the newest Denons 7200XWA (so, HDMI transport and/or Denon Link 4). I am less concerned with video processing than reliable, digital full Hi-Rez transport from player to Receiver, I have noted it can be hard to pinpoint players that downscale or pass DSD off as hi-res PCM.
I'm open to suggestions, including both new and used gear, hopefully reasonably-priced, and far less than the 1.5K for the 3910.
I've done a few searches already, with more questions than answers, and thanks in advance to any help you can provide.
P.S. For those who asked, I have several archived DVD-3910 firmware releases, PM me for any specific requests, Thanks in advance.
Mandrax is offline
post #7512 of 7513 Old 03-18-2016, 04:07 AM
pbarach's Avatar
Quoted: 365 Post(s)
Liked: 215
Oppo 103 will do everything you need. If you plan to use 6-channel analog output instead of HDMI for audio, consider the Oppo 105.
I use my 3910 as a transport for a headphone amp, still works great.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K702, Hifiman HE-400i, Marantz HD-DAC1 (also used for music playback in the main system, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #7513 of 7513 Old 07-09-2016, 02:50 PM
Liked: 0
Hello Mandrax,
Recently I have obtained beautiful 3910, but it has a problem on HDMI output.
I have checked its firmware is 6609-2, so there is a chance to improve with upgrade. Please reach me if you are still available here.
Thank you
tp28 is offline
Reply DVD Players (Standard Def)
