What is MacroBlocking? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-20-2004, 02:50 PM - Thread Starter
AkaStp's Avatar
Sorry if this is a dumb question, but....what is MacroBlocking? I've seen it mentioned in conjunction with several upconverting DVD players but have not been able to find a clear explanation of what it is.
AkaStp is offline
post #2 of 13 Old 09-20-2004, 02:53 PM
Joxer's Avatar
Its an MPEG artifact when the bitrate is insufficient for the fast motion scenes that results in relatively large square blocks appearing.
Joxer is offline
post #3 of 13 Old 09-20-2004, 03:22 PM
rynopr's Avatar
OK, how about a simple explanation like that for the chroma bug.
rynopr
rynopr is offline
post #4 of 13 Old 09-20-2004, 04:56 PM
ethanj's Avatar
If macroblocking is the result of insufficient bit rate, how is this the fault of the player?
ethanj is offline
post #5 of 13 Old 09-20-2004, 06:33 PM
ethanj's Avatar
If the player is optimized to reveal more details than are really there
Isn't this a good thing?
ethanj is offline
post #6 of 13 Old 09-20-2004, 07:31 PM
Kevin C Brown's Avatar
Liked: 27
That's not really it.
If you look on pg 7 or 8 of the 3910 macroblocking thread, there are pictures posted by vetboy and rider that show it perfectly.
Basically, a player that has the "macroblocking problem", exagerates a specific type of MPEG2 compression artifact.
All players have this to some degree, and there are DVDs out there that are mastered with more compression that are more susceptible, but for some reason, the 3910 and 5900 tend to exhbit this "problem" more. It is very specific to certain displays and DVDs.
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ... Something old and something new :-)
Kevin C Brown is offline
post #7 of 13 Old 09-20-2004, 07:58 PM
ethanj's Avatar
Kevin, thanks. Those pictures show the macroblocking problem perfectly. I have seen this before on my setup (Z2/cheap Sony DVD), but wasn't sure what it was until now.
ethanj is offline
post #8 of 13 Old 09-21-2004, 12:40 AM
Liked: 27
Yuppers. I have seen it on Pioneer, Panasonic, and Sony players too (the first Blade DVD). Just that for some DVDs and displays, it shows up more often with those two Denon players. Although... Expletive who had a 5900, and when he perfectly calibrated his display, the 3910 didn't have the problem to the extent the 5900 did:
http://www.avsforum.com/avs-vb/showt...69#post4374569
But then later on here's what Rider has to say:
http://www.avsforum.com/avs-vb/showt...30#post4380230
Me? I have a CRT HDTV with only component input, so I'm still leaning to get the 3910. :)
post #9 of 13 Old 09-21-2004, 05:24 AM
Eddie Horton's Avatar
Is macroblocking the same thing as "black ghosting"?
The previous post may contain spoilers, which will make the post less aerodynamic and increase handling at high speeds.
Eddie Horton is offline
post #10 of 13 Old 09-21-2004, 06:28 AM
James W. Johnson's Avatar
Is macroblocking the same thing as "snowballing"?
j/k :D
James W. Johnson is offline
post #11 of 13 Old 09-21-2004, 07:15 AM
After seeing the movie "Clerks", I'd have to say no. :D
post #12 of 13 Old 09-21-2004, 08:58 AM
I am glad you didn't say "from experience"! :D
post #13 of 13 Old 09-21-2004, 09:00 AM
No worries there!
Closed Thread DVD Players (Standard Def)
