Pioneer 59avi vs Denon dvd-3910 - Page 14 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #391 of 407 Old 12-10-2004, 12:50 AM
Kevin C Brown's Avatar
Liked: 27
I have found that a nice ale aids in equipment selection decisions! ;)
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ... Something old and something new :-)
Kevin C Brown is offline
post #392 of 407 Old 12-10-2004, 01:58 AM
Digital Puppy's Avatar
You guys are starting to make me have buyers remorse - on the popcorn method that I use for my home theater! Must go back to the archives and do some more research!!!
Darn you guys!
Just a little puppy trying to make it in a big digital world.
Digital Puppy is offline
post #393 of 407 Old 12-12-2004, 09:32 AM
mskreis's Avatar
Quoted: 49 Post(s)
One point that has been made many times is the importance of the display. Many favorable comments come from users with very high end displays. I have an 8700+ and a Bravo D1, which continues to be very problematic (the D1). I'm very pleased with the 720p image over DVI but am tired of all the D1 glitches. I would like a better, more reliable player and am considering the 59avi. I know it would be much more reliable but will I see an improvement in the picture on my Benq?
JVC RS57; Marantz AV7702mkII; Lumagen Pro 4240; Oppo BDP-203;Triad Silver LCR, Onwall Bronze Surround, Inwall Bronze Omni; SVS 20-39 PC+
mskreis is online now
post #394 of 407 Old 12-12-2004, 09:49 AM
Rob Tomlin's Avatar
My Bravo D1 took a dump one month after the warranty expired, otherwise I would have made it part of the shootout with the Denon, Pioneer and Onkyo.
Rob Tomlin is offline
post #395 of 407 Old 12-13-2004, 01:41 PM
Expletive's Avatar
Quoted: 47 Post(s)
I've got a 59avi and a 3910 in my possession now if anyone would like me to try anything. Ive got them hooked up to an optoma H77 through a Lumagen HDP. I'll be doing some 480i comparisons over component and 480p over HDMI/DVI for sure, other than that i'm open to suggestions.
John
Expletive is offline
post #396 of 407 Old 12-13-2004, 03:57 PM
mskreis's Avatar
Quoted: 49 Post(s)
Expletive, our projectors are similar as they both use the HD2+ chip. Any way you can get a Bravo D1 or Momitsu to compare to the 3910 and 59avi?
post #397 of 407 Old 12-13-2004, 05:00 PM
steviec's Avatar
Kris, Please respond...Is the 480i hdmi output from a Pioneer 59avi the same as a 480i sdi output from a Denon 5900 or 3910 ? thanks!
steviec is offline
post #398 of 407 Old 12-13-2004, 05:15 PM
Rob Tomlin's Avatar
John
Is that pj's native resolution 720p?
If so, I would certainly do the majority of comparison at 720p via HDMI. Look for any differences in noise, sharpness, clarity, edge enhancement etc. and let us know what you find!
post #399 of 407 Old 12-13-2004, 05:16 PM
thebland's Avatar
Quoted: 1498 Post(s)
Liked: 851
HDMI does YCbCr 4:2:2 and 4:4:4 with up to 12bit color component precision. SDI outputs YCbCr 4:2:0 from the MPEG decoder.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
post #400 of 407 Old 12-13-2004, 05:26 PM
steviec's Avatar
So Jeff what you are saying is that 480i over hdmi is superior to any sdi output?
steviec is offline
post #401 of 407 Old 12-13-2004, 06:34 PM
Kir
Kir's Avatar
Quoted: 27 Post(s)
I think he's saying that SDI is a direct output from MPEG decoder, while HDMI through some post-processing.
<When did I become an interpreter?> ;)
Kir is offline
post #402 of 407 Old 12-13-2004, 07:05 PM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 289 Post(s)
Liked: 4118
I first thought that SDI output YCrCr 4:2:0, but then after reading the Secrets article on the "Chroma Upsampling Error" which can happen when the MPEG decoder is upsampling to make YCbCr 4:2:0 into YCbCr 4:2:2. So now I believe that SDI outputs 4:2:2 which is what comes out of the MPEG decoder. Interesting reading and easy to understand: http://www.hometheaterhifi.com/volum...ug-4-2001.html So, HDMI YCbCr 480i and SDI output should be the same data. With HDMI you may get a choice of YCbCr 4:2:2 or 4:4:4. The MPEG decoder will only output one or the other for SDI.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #403 of 407 Old 12-13-2004, 07:07 PM
Krobar's Avatar
Quoted: 17 Post(s)
AFAIK HDMI should can be identical to SDI. The problem is it can also not be, correct me if im wrong but dont most HDMI solutions currently output 4:4:4. which would make them inferior to SDI for DVD use.
An HDMI projector does have an advantage if implemented correctly, some dvd players have 10 or 12 bit mpeg decoders, if the HDMI output uses the same 10 or 12 bit YCbCr ouput then it could manage a tiny improvement in colour over SDI (Most current digital displays cannot display more than 8bit colour though).
SDI has longer cable lengths and no HDCP though so if cost is no issue I'd go SDI every time for DVD use.
Krobar is offline
post #404 of 407 Old 12-13-2004, 07:12 PM
steviec's Avatar
Krobar that is what I thought.
So sdi is still the preferred way to input 480i into a scaler until we are sure of what exactly the hdmi of a particular player is outputting.
steviec is offline
post #405 of 407 Old 12-13-2004, 07:14 PM
Moderator
Moderator
Quoted: 289 Post(s)
Liked: 4118
The data on the DVD is 8bit YCbCr 4:2:0. The MPEG decoder will upsample into 8bit YCbCr 4:2:2 or 4:4:4. You may be thinking of video DACs that upsample using 10, 12, and now 14bits at 216Mhz(?). This is for analog output. HDMI can transmit YCbCr 4:2:2 and YCbCr 4:4:4 with 8, 10, or 12bit color components.
larry
post #406 of 407 Old 12-14-2004, 02:37 AM
Expletive's Avatar
Quoted: 47 Post(s)
Nope, sorry.
John
post #407 of 407 Old 12-14-2004, 11:56 AM
Krobar's Avatar
Quoted: 17 Post(s)
I thought MPEG decoders often ran at 10/12bit to avoid rounding errors, by using a 12bit transfer you would avoid reintroducing those errors. Af far as I remember with the right SDI mod you connect 10 data wires to give 10 bit, the problem is that all consumer video processors only accept an 8bit SDI signal.
Edit : Tidied up 10bit SDI info and heres proof of 10bit output from the Denon 5900 Decoder:
http://www.avsforum.com/avs-vb/attac...157&fullpage=1
Krobar is offline
Closed Thread DVD Players (Standard Def)
