My preliminary impression of I-O DATA AVEL LINKPLAYER2 - Page 148 - AVS Forum | Home Theater Discussions And Reviews
post #4411 of 4424 Old 03-12-2009, 11:55 PM
aviationbje's Avatar
I downloaded the advanced server from the link you posted, but I'm not sure exactly how to get it running. I installed it and opened it up on my pc but when I put my ip address into my Avel Link Player it immediatly pops up saying could not connect. I have Avel Link Server working but I am also trying to get MKV's to work. Any help woul dbe greatly apperciated.
aviationbje is offline
post #4412 of 4424 Old 03-13-2009, 10:06 AM
RalphArch's Avatar
It's been years since I set it up - and back then we had the web site with forum and directions. Maybe others remember the set up specifics but I don't and rarely use the advanced server anymore - I use ps3 mediaserver mostly which I believe will handle/decode the files you are interested in if your computer is fast enough (mine isn't but Iam only streaming ATSC files)
If you bought recently maybe you can complain to igsshop.com for selling without supporting. But it was a beta even back then.
Or go to their japan site to see if directions / support exist there but you need to speak japaneese http://www.iodata.jp/
RalphArch is offline
post #4413 of 4424 Old 03-13-2009, 06:07 PM
I got PS3 Mediaserver to show up on my JVC-SRDVD-100U but when I go into it, it says "no movies in default video folder" in the Shared Folders section of Java PS3 Media Server, I have put two folders in the list. One that contains a single mkv, and one that contains several avi's.
post #4414 of 4424 Old 03-13-2009, 08:12 PM
RalphArch's Avatar
Perhaps it was a bad recommendation. I put a single avi file into one of my video folders and using ps3 server the lp2 didn't display that file for me. The server built into the drive displayed it but wouldn't play it so I know it was there
My use of ps3 server is really limited to ts tp and mpg files
post #4415 of 4424 Old 02-05-2012, 10:15 AM
buckeye1010's Avatar
Does anyone know where I can download any of the Avel Link firmware? Please help!
Buckeye1010
Dayton, OH
buckeye1010 is offline
post #4416 of 4424 Old 02-05-2012, 10:52 AM
bigrig's Avatar
Quoted: 27 Post(s)
I've got a few I could throw onto the web. Any one in particular you want?
Edit - I threw them all in a zip file, you can download it here: http://www.filedropper.com/linkplayerfirmware
"It's an invention, and it makes Non-Stop Rocking possible!"
bigrig is offline
post #4417 of 4424 Old 02-05-2012, 11:09 AM
WOW - thank you so much!!! I was messing around with my old Avel Link trying to get it to play a particular format. I did a revert to earlier firmware, and I thought I had saved those versions on CD or hard drive. WRONG! I had done all my fw updates over the Internet. That teaches me a lesson - don't update through the player - do it on the Internet and move it with media!
Thanks again - my day went from bad mood to GREAT mood!!
-Bruce
Buckeye1010
Dayton, OH
post #4418 of 4424 Old 02-05-2012, 12:29 PM
bigrig's Avatar
Quoted: 27 Post(s)
Cool, glad I could improve your day!
bigrig is offline
post #4419 of 4424 Old 03-16-2012, 10:30 PM
mrfiat's Avatar
Hi,
Can someone post the linkplayer firmware version up again on filedropper?
TIA.
mrfiat is offline
post #4420 of 4424 Old 03-16-2012, 11:07 PM
bigrig's Avatar
Quoted: 27 Post(s)
Originally Posted by mrfiat View Post
Hi,
TIA.
Should work now - http://www.filedropper.com/linkplayerfirmware
bigrig is offline
post #4421 of 4424 Old 08-04-2012, 05:15 PM
Zandman's Avatar
Looks like the link is down again. A re-post would be much appreciated.
I also need the Advanced Server software. I tried downloading it from the Japanese site but it won't accept my players S/N. I would be much obliged to anyone who would help by posting this app. TIA
Zandman is offline
post #4422 of 4424 Old 08-04-2012, 05:46 PM
akahan's Avatar
I'm there for you, man. Linkplayer firmware and software, multiple versions. I've posted them here:
ftp.swanarchives.org
login: philbin
password: Dryuptubb0
Note that the last character in the password is a zero.
Enjoy, and I hope it helps.
akahan is offline
post #4423 of 4424 Old 08-04-2012, 09:01 PM
Zandman's Avatar
Way to come through akahan! Thanks a bunch.
Zandman is offline
post #4424 of 4424 Old 08-07-2012, 06:22 PM
Arrius's Avatar
Hi Akahan,
Since i follow this thread since quite a lot of time, I will remove the dust on my sleeping AVLP2 and try to resurrect it thanks to your files.
Let's see what I will get from it!
Thank you!
Kami
Arrius is offline
Reply DVD Players (Standard Def)
