My preliminary impression of I-O DATA AVEL LINKPLAYER2 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 4424 Old 11-09-2004, 09:44 PM
Tom Roper's Avatar
Quoted: 250 Post(s)
Liked: 251
When generating my own HD tests at around 3.5Mbps, the resulting encodes looked excellent. And at this bit rate you can store over 2 hours of material on a single sided, single layered DVD~R/RW... which I think is ideal.
You can get nearly 5 mb/s (video + audio) on a 2 hour single layer DVD.
But in my case with 30 fps, even 5 mb/s WM9 is on the margin for hi-def, 8 mb/s is starting to get good, and 9.2 mb/s is where the encode becomes virtually indistinguishable from the source.
Remember, the WM9 720p trailers are only 24 fps. They can succeed with a lower bit rate than 30 fps video.
HDR Colorist and Conversions
INTO THE CAVE OF WONDERS
Directed by MANUEL BENITO DE VALLE Produced by PEDRO PABLO FIGUEROA
Cast MANUEL ANGEL REINA, CLAUDIA GARROTE
LOVETHEFRAME STORIES, SOUNDTRACKS AND FILMS
Tom Roper is offline
post #182 of 4424 Old 11-10-2004, 02:52 AM
Wilbert's Avatar
How does this thing handle subtitles? Do they need to be muxed into the avi? Burned into the image? Seperate ssa or srt file?
You can't mux subs into avi (well, you can mux ssa and perhaps other formats into avi with avimux, but not many software players support that). In theory it should be able to play avi+external subs (*.sub and perhaps *.srt). TUFU tested some of these streams (I will send him a few other ones), but the subs didn't show up. Perhaps he can send a mail to these iodata guys, asking about this ...
Wilbert is offline
post #183 of 4424 Old 11-10-2004, 07:21 AM - Thread Starter
TUFU's Avatar
1. The WM9 file I made was 1280x720 which was transcoded from a 720p
HD TS film with HT MPEGENCODER 7.0 choosing "windows media codec 9".
2. Hi Kermee,I had connected AVLP2's analog stereo sound output to test
the file without sound. The result is still no sound.
3.I also was told that I-O DATA in Japan are going to release a new firmware in the end of November which will support WMA PRO. I don't know
whether WMT DRM will also be included. I hope so.
4.Regarding the issue of subtitle, I had got one responsefrom here
http://forums.divx.com/viewtopic.php...61648&forum=21
TUFU is offline
post #184 of 4424 Old 11-10-2004, 07:28 AM
JS - DBD's Avatar
Has anybody got a reply regarding the DVI output of DVD-V?
I am very exited about this device.
It has everything I want. But the DVI issue is a showstopper for me.
JS - DBD is offline
post #185 of 4424 Old 11-10-2004, 08:07 AM
dschamis's Avatar
Quoted: 12 Post(s)
What's the latest on being able to play "store-bought" DVDs w/ Macrovision, etc., at HD resoultions?
David
dschamis is offline
post #186 of 4424 Old 11-10-2004, 08:20 AM
dschamis's Avatar
Quoted: 12 Post(s)
Compared to the Momitsu V880N, how is this better?
dschamis is offline
post #187 of 4424 Old 11-10-2004, 08:26 AM
lowmazda's Avatar
Noticed that IO Data is showing this unit is now in stock in the US. Hope we get a few more 'testers' out there.
lowmazda is offline
post #188 of 4424 Old 11-10-2004, 09:22 AM
Dolfo's Avatar
The Momitsu upconverts regular video (DVDs and such), but I don't believe it supports playback of HD video such as Divx-HD and WMV-HD. That is the main difference, though this difference isn't so significant to some people due to the short supply of commercial video that uses either of these HD schemes. I already have an upconverting DVD player and would like to replace it with a player that does the same and adds networking and HD playback of some sort. It looks like this IO Data player is shaping up to be that replacement, but I may be looking at the Momitsu player more if they don't fix some of the bugs that I consider significant by the time they launch the DVI version in the U.S. We'll see.
-- Adolfo
Dolfo is offline
post #189 of 4424 Old 11-10-2004, 09:32 AM
Tom Roper's Avatar
Quoted: 250 Post(s)
Liked: 251
Just checked my online order status...order date 11/02/04
- not shipped -
post #190 of 4424 Old 11-10-2004, 09:34 AM
dschamis's Avatar
Quoted: 12 Post(s)
Originally posted by Tom Roper
Some of you asking questions will find the answers if you read the thread.
Tom - I realize this, and I know it is seen as obnoxious to the people who have been following this day-to-day, but sometimes it is much more efficient, when you have a very specific question, to just post it and look for a quick reponse.
David
dschamis is offline
post #191 of 4424 Old 11-10-2004, 09:59 AM
dschamis's Avatar
Quoted: 12 Post(s)
Originally posted by Busybusy
IO data player WILL NOT allow playing back DVD movies from DVI, and if Macrovision is on, then there will be no 720P/1080i from the D4 connector. Regardless of Sigma Chip's capability, it's each manufacturer's decision to follow DVD Forum/Macrovision's requirements.
The DVI output is not HDCP because playing back movies/Divx from HD/PC who cares about HDCP?
This is very, very clearly stated and my biggest reservation.
Does this mean that we can't get 1080i/720p from any store-bought DVDs, regardless of whether we use DVI or component?
dschamis is offline
post #192 of 4424 Old 11-10-2004, 10:10 AM
gtrogue's Avatar
Someone correct me if I'm wrong, but it seems that you can get upconverted 1080i or 720p DVD-V from the analog component output but not the DVI output.
T.
gtrogue is offline
post #193 of 4424 Old 11-10-2004, 11:28 AM
Dolfo's Avatar
TUFU mentioned on page 6 of this thread that:
"The DVD-VIDEO in DVD-ROM can only output from component , S or composite NOT DVI. But,DVD-VIDEO in DVD-ROM can toggle between 480p,720p,1080i in my projector Mitsubishi D1208 which was HDCP comliable"
TUFU, can you please confirm this? Do commercial DVDs (with macrovision) play AS IS via component output from the player's DVD-ROM drive at upconverted HD resolutions?
-- Adolfo
Dolfo is offline
post #194 of 4424 Old 11-10-2004, 12:10 PM
MVBJJ's Avatar
I asked this question via email to I-O Data and this is the response I received. This seems to conflict with what TUFU has reported. But even the response I received below seems conflicting. For my needs, I really need to know if this player does upconvert store bought DVDs (or DVD back-up copies).
Dear Michael,
I have some feedback from our engineer.
> when I play a DVD movie disc if the player will upconvert through
> component jacks from 480p to 720p and 1080i
Our LinkPlayer doesn't have such a function unfortunately.
Therefore, if you just enjoy 480p DVD playback on HD TV. Basically 480p source is 480p source.
Our LinkPlayer is providing the best 480p / 720p / 1080i by
each video quality with some digital tuning (4tapInterpolation and
others).
MVBJJ is offline
post #195 of 4424 Old 11-10-2004, 12:45 PM
gtrogue's Avatar
The language difference makes any answers you get hard to decipher from these guys.
Perhaps your question confused them. Standard NTSC DVD-Video discs do not contain 480p video.
T.
gtrogue is offline
post #196 of 4424 Old 11-10-2004, 01:06 PM
Tom Roper's Avatar
Quoted: 250 Post(s)
Liked: 251
I think it's pretty clear from TUFU and I-O Data:
1.) The U.S. spec player doesn't have DVI.
2.) Store-bought (encrypted) DVDs will not up-convert.
3.) Decrypted DVDs will up-convert to 720p/1080i.
Go elsewhere for mainstream upconverting DVD players.
post #197 of 4424 Old 11-10-2004, 01:14 PM
Dolfo's Avatar
TUFU - can you confirm Tom's conclusions (except, of course, the first one - we already know that the U.S. will see 2 versions of this player and that one of them will have DVI and wireless LAN support as the Japanese version does)? I thought one of your posts implied that store-bought DVDs do upconvert via component output.
-- Adolfo
Dolfo is offline
post #198 of 4424 Old 11-10-2004, 01:28 PM
Tom Roper's Avatar
Quoted: 250 Post(s)
Liked: 251
My unit shipped!!!!!!!!
Just got email confirmation....Fed Ex 2nd day
Should have it Friday (fingers crossed)
post #199 of 4424 Old 11-10-2004, 01:44 PM
SeeMoreDigital's Avatar
Quoted: 468 Post(s)
Liked: 197
....Standard NTSC DVD-Video disc's do not contain 480p video.
Yes they do!
Both PAL and NTSC DVD's can store video "progressively"
Cheers
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #200 of 4424 Old 11-10-2004, 02:07 PM
Wilbert's Avatar
@TUFU,
Two more samples (with *internal* subtitles, muxed with avimux):
1) XviD+ac3+srt
http://www.geocities.com/wilbertdijkhof/avi_ac3_srt.avi
2) XviD+ac3+ssa
http://www.geocities.com/wilbertdijkhof/avi_ac3_ssa.avi
Wilbert is offline
post #201 of 4424 Old 11-10-2004, 02:28 PM
dschamis's Avatar
Quoted: 12 Post(s)
That's all I need to hear - I just pulled the trigger on the Momitsu V880N - I love being a guinea pig as much as the next guy, but not being able to up-convert store-bought DVDs is more than I feel like handling right now.
David
dschamis is offline
post #202 of 4424 Old 11-10-2004, 02:28 PM
Quoted: 468 Post(s)
Liked: 197
Hi Wilbert,
Something's wrong Captain. All I get is this: -
Cheers
post #203 of 4424 Old 11-10-2004, 02:44 PM
gtrogue's Avatar
Originally posted by SeeMoreDigital
Yes they do!
Cheers
I've never bought a commercially available DVD that had "progressive" video on it.
T.
gtrogue is offline
post #204 of 4424 Old 11-10-2004, 02:48 PM
Dolfo's Avatar
Me neither. I don't even know of any DVDs that have 480p programmed onto it, though I guess it is possible to do so.
-- Adolfo
Dolfo is offline
post #205 of 4424 Old 11-10-2004, 02:48 PM
Tom Roper's Avatar
Quoted: 250 Post(s)
Liked: 251
They are rare in U.S.
They do exist.
post #206 of 4424 Old 11-10-2004, 02:49 PM
gtrogue's Avatar
On the subtitle front.
Here's what I got from I-O Data:
"Thank you for the message.
Our LinkPlayer supports:
1. DVD movie subtitle
2. DivX subtitles (SRT, BMP, and others)
Thanks."
T.
gtrogue is offline
post #207 of 4424 Old 11-10-2004, 02:53 PM
gtrogue's Avatar
Isn't there an edition of Digital Video Essentials that has true progressive scan video on it. I seem to remember some talk about this in regards to DVE.
T.
gtrogue is offline
post #208 of 4424 Old 11-10-2004, 02:56 PM
Quoted: 468 Post(s)
Liked: 197
You've got to be kidding....
Most if not all commercially released "movie" DVD's are progressive!
They are of course all a released within an 720x480 or 720x576 anamorphic frame.
Why do you think we have stand-alone players that are labelled as having "progressive output"?
Cheers
post #209 of 4424 Old 11-10-2004, 02:58 PM
Tom Roper's Avatar
Quoted: 250 Post(s)
Liked: 251
Right you are! This fact is mentioned on the Secret Benchmark for Home Theater website also...
post #210 of 4424 Old 11-10-2004, 02:58 PM
gtrogue's Avatar
SeeMoreDigital, you're kidding, right?
T.
gtrogue is offline
Reply DVD Players (Standard Def)
