Received sony upconverting dvd player today - Page 5 - AVS Forum
Closed Thread
post #121 of 135 Old 11-03-2004, 08:22 PM
juandixon's Avatar
5.1 audio vs digital audio for movies???
i know sacd only works with 5.1, so which on is better for movies?
my receiver handles both...what do you guys use?
juandixon is offline
post #122 of 135 Old 11-03-2004, 08:45 PM
jeeper78's Avatar
I myself would rather send a digital bitstream to my receiver than the analog 5.1.... I guess it's a question of would you rather have your receiver or your DVD player decoding the digital signal.
jeeper78 is offline
post #123 of 135 Old 11-04-2004, 08:54 AM
csimington's Avatar
The manual actually states that with the player set to AUTO for the video signal, it outputs the highest resolution that your TV will accept. I assume this means that it will output 1080i to any set which accepts it - probably all HDTVs.
This is true. In Auto mode the DVD player sends 1080i to my Samsung HLP and not the native resolution of 720p. I had to manually select 720p. I have not determined which resolution looks better yet, but it would seem that since the Samsung would have to convert the 1080i and not have to covert the 720p signal that the 720p signal would be better.
Clark
csimington is offline
post #124 of 135 Old 11-04-2004, 12:57 PM
Koy
Koy's Avatar
juandixon - I use both 5.1 and digital and use the one that produces the best sound based on the dvd movie I'm playing.
PSN: Bloodstryke
Live: Ferocious Gamer
Koy is offline
post #125 of 135 Old 11-08-2004, 02:44 PM
drjeckl's Avatar
So where did this thread go? I dont see it in the list at the forum level but I remembered the thread id? Did this get replaced with the "Brain Dump" thread?
drjeckl is offline
post #126 of 135 Old 11-08-2004, 02:46 PM
drjeckl's Avatar
Resurrected from the dead.
drjeckl is offline
post #127 of 135 Old 11-08-2004, 08:35 PM
umr
AVS Club Gold
umr's Avatar
Liked: 29
I just got my hands on the service manual for this player. Here are some facts.
It uses a Silicon Image HDMI transmitter...
http://www.siimage.com/products/overview_sii9030.asp
The video DAC is an ADV7300...
http://www.analog.com/en/prod/0,2877,ADV7300A,00.html
The audio DAC is an AK4358....
http://www.asahi-kasei.co.jp/akm/en/...58/ak4358.html
The deinterlacer and scaler appear to be Sony proprietary IC's.
umr is offline
post #128 of 135 Old 11-08-2004, 08:43 PM
Paul Bigelow's Avatar
The ADV7300 has built in SD and HD test patterns?
Wouldn't that be great to access!
Paul
Paul Bigelow is offline
post #129 of 135 Old 11-09-2004, 05:41 AM
chris523's Avatar
umr,
Where did you get the SM from?
-Chris
chris523 is offline
post #130 of 135 Old 11-09-2004, 05:59 AM
umr
AVS Club Gold
umr's Avatar
Liked: 29
Originally posted by chris523
umr,
-Chris
Sony service.
umr is offline
post #131 of 135 Old 12-20-2004, 07:49 PM
tvted's Avatar
There is no such thing as SACD for DVD Movies. It is an Audio only bitstream and is not defined for DVD - not even with the upcoming HD formats.
Connect both for usage with SACD and DVD.
ted
tvted is offline
post #132 of 135 Old 12-21-2004, 06:35 AM
kdog044's Avatar
ted
I believe his question was whether the 5.1 analog or digital output would be better for audio when playing DVD's. I believe he understands the 5.1 analog connections are needed for SACD.
kdog044 is offline
post #133 of 135 Old 12-21-2004, 08:20 AM
Auditor55's Avatar
Originally posted by alwayswanting
Received the sony dvd player today(ordered from sony style). My first reaction is that I am not very impressed. It did not blow me away as I had expected. The picture has a soft look to it, even in 1080i via hdmi cable. My tv is a CRT which has been known to not have a great effect with upconverting dvd players. I did however own the denon 1910 for a few weeks and the picture quality of that machine was a TON sharper then the sony. If denon didnt have the shake at 1080 and the green push I would have kept it in a heart beat. I feel from what I have owned is that the denon 1910 is the best if it didnt have the green push/shake. Sony would be second. Then the Zenith. I saw no problems with the sony via hdmi. Black crush, white crush, push of a color, etc. The sound of the Sony was REALLY good(probably due to the hdmi cable). If anyone has any questions let me know. I am not a guru, so keep em simple.
Why don't you just buy a good quality 480P DVD player and forget about an upscaling player. I'm very distrustful of upconverting DVD players, seems a bit like "snake oil" to me. Why don't you just wait until true HD-DVD comes out and stop waisting money on some "cheesy" so-called upconverting player.
Auditor55 is offline
post #134 of 135 Old 02-18-2005, 08:56 AM
bruman's Avatar
I can say my zenith shows no difference on my sony crt.
but this sony 975 does look upconverted.
bruman is offline
post #135 of 135 Old 09-27-2005, 08:15 AM
raymondeast's Avatar
how does the sony look on the z2 projector?
raymondeast is offline
Closed Thread DVD Players (Standard Def)
User Tag List
